MikhailModeratorPlease compare the moment of receiving new data using Communication Line Log page of SCADA-Communicator. In this page incoming data are shown as soon as they received.
What will be the difference beetween the applications if you measure in the described way?
MikhailModeratorI understand your idea. To be honest, I had the same thoughts. But it is not supported. The other approach is preferable. Most likely SCADA-Web would contain a system of visual components those implement dynamics.
MikhailModeratorHow did you measure the delay?
You can reset this kind of value by using Generator of SCADA-Server. But it is not suitable for your case. I think the best way of implementing the functionality you need is defining your own formula that calculates switching and supports reset.
MikhailModeratorCould you upload your screenshot to the web using image hosting, for example, postimage.org ? I can’t view the image from drive D of your PC.
No formula is needed for sending Off and On.
Have you got a message “The command is in the queue for execution” from SCADA-Web?
Probably you didn’t click Execute button after selecting command value.
You can change command radio buttons to buttons in this web form using SCADA-Web Configurator (Simple commands sending checkbox).
MikhailModeratorPlease check that the directories specified in SCADA-Server
and shown here are exist.
Did you install Rapid SCADA in C:\SCADA directory?-
This reply was modified 11 years, 2 months ago by
MikhailModeratorFor the reason that XP is outdated OS, SCADA-Web can’t be installed automatically. Manual installation of SCADA-Web is needed. Follow the steps described in Doc\manual_setup.pdf in the installation package.
MikhailModeratorI can, but it would be inconvenient for other users.
Please describe occured issues in details.
What installation steps have you done?
What errors did you get?
The behavior of channels of Switching Counter type is hardcoded.
The algorithm is:
Fill Formula field of the channel by any correct formula and tick Formula Used checkbox.
When the value of the formula crosses 0, the value of the channel will increase by 1.
MikhailModeratorYes, you can set it to 10 or 1 second, for example. But you can’t do it using graphical interface of SCADA-Server. If you need it, do it manually by editing C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml in the text editor you like.
This mode hasn’t been tested yet, it works, most likely. In this case it is a good idea to monitor size of files in C:\SCADA\ArchiveDAT and C:\SCADA\ArchiveDATCopy
MikhailModeratorWithout registration Automatic control module works in the test mode. I think it is a good idea to add the full featured mode limited by date.
If you send the computer code generated by the module to info _aty_ rapidscada _dot_ org, I generate a trial key.The same option for the chart is unavailable due to technical reasons.
The chart component overrides the default chart and just adds the declared functionality.
MikhailModeratorAs a workaround you can manually set the value in C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml
It defines how often snapshots are stored in minute data file. SCADA-Server shell may display custom values incorrectly despite of that it works.
If you write more details about your task I could give more efficient advice.
MikhailModeratorI’ve sent the file to you via e-mail.
The file is missed in the installation package. It will be added ASAP. -
