Installation errors
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Installation errors
  • #55
    akbarm
    I am new to SCADA systems and tried to install rapidscada on a Windows 7. The installer ends up with 2 errors for installing the services. Do you have any idea?
    After restart, two SCADA services are appeared in the Services which are started with no problem. But, SCADA-Web does not work. The login page is loaded, but I can’t login , with error message “Unable to login, the server is unavailable”.
    Every comment or help is welcome.
    #56
    Dear Akbarm,
    Please post the following additional information about the issue:
    1. What were the errors occured during installation?
    2. What is the state of SCADA-Server when it runs? The state is written in C:\SCADA\ScadaServer\Log\ScadaServerSvc.txt
    This issue often appears if some other application uses TCP port 10000. For example, torrents client. In this case, close that application and restart SCADA-Server service.
    #135
    kallileo
    I have the same problem.
    The output in the ScadaServerSvc is:
    2015-03-21 12:36:04 <I5-4570><SYSTEM><ACT> ScadaServerService is started
    2015-03-21 12:36:04 <I5-4570><SYSTEM><ERR> The configuration database in DAT format directory does not exist.
    The interface directory does not exist.
    The archive in DAT format directory does not exist.
    The archive copy in DAT format directory does not exist.
    2015-03-21 12:36:04 <I5-4570><SYSTEM><ERR> Normal program execution is impossible.
    tcp
    Thanks in advance.
    #137
    Please check that the directories specified in SCADA-Server
    and shown here are exist.
    Did you install Rapid SCADA in C:\SCADA directory?
    • This reply was modified 11 years, 7 months ago by Mikhail.
    #144
    kallileo
    Yes, the directories in server configuration weren’t properly configured.
