Without registration Automatic control module works in the test mode. I think it is a good idea to add the full featured mode limited by date.
If you send the computer code generated by the module to info _aty_ rapidscada _dot_ org, I generate a trial key.
The same option for the chart is unavailable due to technical reasons.
The chart component overrides the default chart and just adds the declared functionality.
