Viewing 15 posts - 6,121 through 6,135 (of 6,265 total)
  • in reply to: Any questions about Rapid SCADA and Raspberry Pi #439
    Use should use /dev/ttyUSB0
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #438
    ls /dev/tty*
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #436
    Specified port name is wrong. What is the full name of ttyUSB0 is listed by Raspberry Pi?
    in reply to: Is it possible to connect SCADA with PostgreSQL #435
    C:\SCADA\BaseSDF – configuration in SQL Server Compact format
    C:\SCADA\BaseDAT – configuration in special format
    C:\SCADA\ArchiveDAT – archives
    in reply to: Advice required for setting up a basic system #432
    If you’d like, I can make necessary settings remotely for a fee. This will save your time.
    If not, let’s continue )
    in reply to: Advice required for setting up a basic system #431
    Hi Bret,
    Probably my explanations were not so clear. You have to use TCP client connection channel. But it is not necessary to set IP address of the TCP client channel, because IP address of your device must be set in Call Number fileld.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #430
    Is the port successfully opened by SCADA-Communicator?
    in reply to: Animated components #427
    The content of CalcEngine.cs is generated according to the configuration database.
    It is compiled from memory and then written to a file.
    Or you wrote a function in the source of the project?
    in reply to: Animated components #425
    calcengine.cs is generated automatically by SCADA-Server. If you copy it manually, it will be overwritten.
    in reply to: Animated components #424
    Is this function compiled correctly if you insert it in a new console project?
    in reply to: Is it possible to connect SCADA with PostgreSQL #422
    Hello Savan,
    It is planned to publish a new version of Rapid SCADA within 10 days. It will contain the data export module which allows export to PostgreSQL.
    in reply to: Unsigned 16 bit variables #420
    Hi Bret,
    It is the primary functionality of the Modbus driver. You can easily find these settings in Device Template Editor. Just double click a device in the tree to open its properties. Then click the button with a pencil.
    in reply to: "Unknown DLL" after upgrade #419
    Hi Bret,
    Great, you guessed it ) In the new version of SCADA-Communicator device driver DLL is independent of a connection type. Special software layer named Connection channel establishes and manages the connection.
    You tuned up SCADA-Communicator almost correct, but in your case you shouldn’t define IP address in the properties of the connection channel. Do it in Call Number field of a device like before.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #415
    You definitely right.
    After configuring using Windows you should copy the content of the follownig folders:
    C:\SCADA\BaseDAT
    C:\SCADA\Interface
    C:\SCADA\ScadaComm\Config
    in reply to: "Unknown DLL" after upgrade #413
    Is there Unblock button in the DLL properties like shown here?
