Unsigned 16 bit variables Forum Home › Forums › Understanding the Software › Unsigned 16 bit variables This topic has 1 reply, 2 voices, and was last updated 11 years, 2 months ago by Mikhail. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts September 6, 2015 at 6:14 pm #418 BretLarkParticipant Hi Mikhail, me again! I have some new registers to read, although I haven’t successfully got my meter reading working yet. The registers require the following: Uint 16 bit (which I believe is 2 bytes) Int 16 bit I also need Uint 32 bit which is 4 bytes so should already exist. Is it possible to have Uint 16 bit or is this a new driver development again? Thanks, Bret September 6, 2015 at 7:26 pm #420 MikhailModerator Hi Bret, It is the primary functionality of the Modbus driver. You can easily find these settings in Device Template Editor. Just double click a device in the tree to open its properties. Then click the button with a pencil. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
