Forum Home › Forums › Installation Issues › "Unknown DLL" after upgrade
- This topic has 5 replies, 2 voices, and was last updated 11 years, 2 months ago by
September 5, 2015 at 3:29 pm #410
BretLark
ParticipantHi Mikhail,
I have completely removed and re-installed Rapid SCADA due to some issues after the upgrade but even with a clean install the new KpModbus.dll doesn’t appear to be recognised. Also, the Device Libraries is empty so I cannot configure the XML file.
This is on Windows 10 so I don’t know if something is stopping the DLL from registering. I posted in the other thread as I though it was something I had done wrong but I’m at a loss now as to what is happening.
Many thanks,
BretSeptember 5, 2015 at 8:54 pm #412
MikhailModeratorHi Bret,
Did you install Rapid SCADA 4 Release 4?
Please, describe the sequence of your installation and upgrade steps.September 5, 2015 at 8:57 pm #413September 6, 2015 at 9:42 am #416BretLark
You sir, are a genius! Blocked DLL files have now been unblocked!
I will configure my connections again.
Thanks,
BretSeptember 6, 2015 at 10:39 am #417BretLark
There seems to be a new problem that I didn’t have previously but it looks like a new feature. With my connections configured as per your previous help and advice all I get in the log file is:
“2015-09-06 11:04:23 Unable to communicate with the device because connection is not established”
Under the Communication Line Parameters tab I usually have “Undefined” selected for the channel type and the connection is completed through the Call Number in Request Sequence. If I change this to TCP Client and add the IP address and port I get a connection. The issue here is that I can only have one device per Communication Line as my devices are all on different public ports.
Has this changed within the software or have I configured something incorrectly?
Thanks,
BretSeptember 6, 2015 at 7:20 pm #419
Great, you guessed it ) In the new version of SCADA-Communicator device driver DLL is independent of a connection type. Special software layer named Connection channel establishes and manages the connection.
You tuned up SCADA-Communicator almost correct, but in your case you shouldn’t define IP address in the properties of the connection channel. Do it in Call Number field of a device like before.
