Is it possible to connect SCADA with PostgreSQL
Forum Home Forums Uncategorized Issues Is it possible to connect SCADA with PostgreSQL
  • #421
    Savan Tripathi
    hello sir,
    I want to connect Rapid Scada with PostgreSQL database. by default rapid scada use its own built in DBMS. so my que is can i connect to postgreSQL? or what is default DBMS used by RAPID SCADA? And Where is DB located?
    #422
    Hello Savan,
    It is planned to publish a new version of Rapid SCADA within 10 days. It will contain the data export module which allows export to PostgreSQL.
    #434
    Savan Tripathi
    Ok Thanks Mikhail. But my question is currently where the data is being stored . I mean what is default built in database for Rapid SCADA. and where it is located??
    #435
    C:\SCADA\BaseSDF – configuration in SQL Server Compact format
    C:\SCADA\BaseDAT – configuration in special format
    C:\SCADA\ArchiveDAT – archives
    #443
    Savan Tripathi
    Ok i got that but .DAT file is belong to which DATABASE??
    #445
    It is a special format.
    This article helps you.
    #501
    Savan Tripathi
    OK This is helpful.
    But my question is, for example i am receiving live data from my device and i want to show that data here in rapid scada web browser, i am receiving data in postgreSQL table, so how can i able to connect it to RAPID SCADA server??
    #502
    In this case you should develop or purchase a driver for SCADA-Communicator or a separate application.
