MikhailModeratorHi Bret,
The field length issue shall be fixed. But it tooks a time.
Are all of your devices have the same port?
In this case you can set “Remote TCP Port” of communication channel properties in SCADA-Communicator and omit port in SCADA-Administrator.Every input channel has a Signal. Signal is an ID of a tag in SCADA-Communicator.
MikhailModeratorHi Dejan,
Yes, use “Status” color. The color depends on input channel status that can be calculated with formula.
It’s easy. Add your messages to Units table like “Alarm states 1” record. Then select created unit for an input channel with Discrete channel type and Text format.
1st message is 0.0 (value)
2nd message is 1.0
etc.
MikhailModeratorSCADA-Web:
Go to C:\SCADA\ScadaWeb\images
Then just overwrite the images.
Also you can change css styles in *.css but is is not recommended because you should do the same task when a new version released.Other applications:
Add the files in the application directory (for example, C:\SCADA\ScadaServer):
About.txtThe content of About.txt:
http://rapidscada.org 232 174 95 23
There the numbers are X, Y, width and height of the link.
MikhailModeratorSwitch to Modules page in SCADA-Server and add ModDBExport.dll
SQL examples are located in Doc\dbexport_en.pdf
In case of questions about DB Export Module, post them in a separate topic.
MikhailModeratorWould you like to insert the logo into the web application only or into all the applications of Rapid SCADA?
Usually it is needed to export hourly or minute archives to Excel. To export current data you could set up export to any database and use the 3rd party tools to export to Excel. Of course you can develop or purchase the custom report.
MikhailModeratora) Yes.
b) Yes, if you use another port of converter.
No, if you use the same port.
c) Yes.
MikhailModeratorIs there error cause in
C:\SCADA\ScadaWeb\log\ScadaWeb.log
C:\SCADA\ScadaServer\Log\ScadaServerSvc.log ?
MikhailModeratorOK, create a separate topic please.
MikhailModeratorEB 76 is the checksum
43 D0 FE 05 is the value 417.984528
You should set the correct bytes order in Device Template Editor.
Try the order 2301.
Please notify me about the result.
MikhailModeratorI would like to see the log.
Can you post here a part of communication line log? And the expected value.
If it is possible also provide MODSCAN log for comparison.
MikhailModeratorThere are a few ways:
1. Export data, then import the same data with other IDs in SCADA-Administrator.
2. Generate SQL queries, connect to ScadaBase.sdf using a tool supports Microsoft SQL Server Compact 3.5 and execute the queries.
3. For input and output channels there are the built in auto create and clone features.-
This reply was modified 10 years, 7 months ago by
Could you provide more details about your task? What kind of data do you need to input?
