User Logo
  • #587
    Garry
    How can we insert our ‘Logo’
    #589
    MikhailMikhail
    Would you like to insert the logo into the web application only or into all the applications of Rapid SCADA?
    #591
    Garry
    Pl tell about both…
    #593
    MikhailMikhail
    SCADA-Web:
    Go to C:\SCADA\ScadaWeb\images
    Then just overwrite the images.
    Also you can change css styles in *.css but is is not recommended because you should do the same task when a new version released.
    Other applications:
    Add the files in the application directory (for example, C:\SCADA\ScadaServer):
    About.txt
    The content of About.txt:
    http://rapidscada.org
    232 174 95 23
    There the numbers are X, Y, width and height of the link.
