MikhailModeratorThe prototype is here http://demo.rapidscada.net/
Login and password as usual: admin / 12345
MikhailModeratorSomething wrong with the image.
It requires changes in SCADA-Server logic. The changes may be done within a common queue of tasks or may be done fast for a fee.As a workaround, limits can be implemented using formulas, but in this case you need separate channels for alarm signalling.
MikhailModeratorDo limits are set for those channels?
Uncheck Event on undefined checkbox for these channels.
MikhailModeratorPlease, remind me by email to send you the prototype.
MikhailModeratorOK, the color and font of the link are not important for me. The link should be visible to users and be clickable. Could you show me a design when its beta version will be ready?
I have to warn that the new web app is fully redesigned and when it will be released, you will need to make design with your brand again. May be it’s better to use the new design as a base. I can send you the prototype.
MikhailModeratorCould you add a link to rapidscada.org with a text like “Powered by Rapid SCADA” near “designed by”?
MikhailModeratorIf you have got a schema of your system, please post it here or send by email. I need deep understanding the communications between the components of the system.
BACnet becomes more and more popular. For the time, you should use 3rd party software or hardware gate to connect BACnet devices to Rapid SCADA. The discussions about BACnet support are here and here.
It is possible to develop a native driver that allows to connect BACnet devices to Rapid SCADA directly. We can discuss the development.
We are planning to release the new modern Rapid SCADA web app provides web UI which works well on different types of clients including Android and iOS. It will be released within a few months.
MikhailModeratorThis idea requires development an additional module for SCADA-Server. It’s interesting.
i will have 10 undefined events
You can create a calculated channel to determine the state of connection instead of using “undefined” events.
MikhailModeratorWhen I start a work of porting the chart component to the new web app, I will do an optimization. Thank you for the useful information, you saved my time.
MikhailModeratorProbably it keeps all the data in a cache.
Are the client and the server on the one PC?
Yes, all you listed can be prepared if required.
MikhailModeratorThanks!
If somebody are able to compare the charting speed with other SCADA software, it would be very interesting and useful.
MikhailModeratorThe issue is enqueued.
