how they work: Events, Alarms and Limits
Forum Home › Forums › Development and Integration › how they work: Events, Alarms and Limits
Viewing 12 posts - 1 through 12 (of 12 total)
  • #1214
    inpelsa
    I can’t find any documentation about this for scada administrator so… questions! Channel columns meaning and use:
    – WRITE EVENTS: means write to the events data file? if not… they are shown today but not saved? Not sure what it is for.
    – EVENT SOUND: will it play some sound on server? on clients table view? on a scheme?
    – EVENT ON CHANGE: on change depending on limits? (which limits are aplicable?) any change respecting last data?
    – EVENT ON UNDEFINED: when is it undefined? no comm data received? after some time? (I think I remember a relationed parameter but don’t remember where is it)
    – LOWER/UPPER LIMIT: what’s the utility of those limits?
    – LOWER/UPPER ALARM: Event generates if below/above this limits?
    Object and device fields… are needed for something?
    Thanks and happy weekend!
    #1215
    inpelsa
    Are any events shown when in Report/List Chart view?
    #1217
    WRITE EVENTS: if false, no event for the channel will be written and shown.
    EVENT SOUND: plays beep in browser. Just try.
    EVENT ON CHANGE: on any change. Usually the option is used for discrete values.
    EVENT ON UNDEFINED: e.g. connection is lost. Event fires when the channel status is 0.
    LIMIT: I recommend trying it using SCADA-Server generator.
    Object field is optional. Device field is required if channel value is measured by a device.
    Sorry, I didn’t catch the meaning.
    Have a nice weekend too 🙂
    #1225
    inpelsa
    WRITE EVENTS… is like “Events enabled” ? I think ‘events enabled’ is more understandable.
    AVERAGING: how does averaging work? continuos average? last 100 values average? last minute average?
    By the way… as only minute-data is shown… what happens when communicator sends several values on the same minute? does an average? maximum? latest?
    Limits… I will try to guess it but that’s not an answer.
    When in a report view with some list chart graphs there are no Events shown. Useless? => hide it, makes you think there are no events.
    #1242
    I agree, “events enabled” is better.
    Averaging:
    Received values are summarized within a period (minute or hour) then divided by their count and the result is stored to archive.
    Events:
    In the new web app the chart list will use the common page template, so events will be visible. Thanks, recently I thought whether it is required or not.
    #1269
    inpelsa
    Just one doubt more…
    As nothing is 100% reliable and this test-wireless link even less… I get some events displayed as: Normal after a loss of link (maybe 3 times a day, but with 100 channels…)
    Is there any option to avoid/ignore NORMAL events caused by a communication error?
    Thanks!
    #1270
    Uncheck Event on undefined checkbox for these channels.
    #1271
    inpelsa
    Hehehehe… I already understood that column…
    Event appears and checkbox is NOT checked!
    #1274
    Do limits are set for those channels?
    #1275
    inpelsa
    http://s32.postimg.org/9fkw5rf5h/.jpg
    Yes, there are limits. Any way to avoid those Normal ?
    • This reply was modified 10 years, 5 months ago by inpelsa.
    #1279
    Something wrong with the image.
    It requires changes in SCADA-Server logic. The changes may be done within a common queue of tasks or may be done fast for a fee.
    As a workaround, limits can be implemented using formulas, but in this case you need separate channels for alarm signalling.
    #1280
    inpelsa
    I tried several times to link image, after 5 minutes i leaved it out, anyway you got it.
    Leave the task for the queue,it’s time to make link reliable!!
