Hi
I am new hear and would appreciate some guidance. I am knew to BacNET and have some questions about a project.
We manafacture an IP intercom and have been asked to provide a solution where by our monitor will also be able to control a BMS system via BacNET.
Our monitor runs android and the intention is to use an app for visualization, the scope calls for the monitor to be able to:
– view energy consumption data from the bms and display graphically.
– control the lighting of the apartment
– control the air con of the apartment
The building will have a fully integrated BMS which will be managing all of the above within each apartment centrally so the controls would need to be for the local area/ unit each monitor is in only.
Our monitor is IP running Kitkat Android.
I hope the above is something you can assist with in terms of hardware and if you can assist with the app etc Im happy to discuss this also.
We are based in Australia and my email is —
This topic was modified 10 years, 6 months ago by
Mikhail. Reason: I removed your email from the post
