MikhailModeratorI can give advice in general or about available functions.
Provide screenshots, please.
The refresh time is the same for all the parameters. All the data are received by a single web request. Otherwise, would be not optimal. Use the smallest value of refreshing.
You should develop your own formulas that calculates average values and reset them when needed. You should enter the formulas into the Formulas table in Administrator and use them from input channels. Also you can purchase creating such formulas.
MikhailModeratorDefinitely, very useful advice. Thanks!
MikhailModeratorIf you decide to start a new development using Rapid SCADA as a platform, I think, we should discuss it, may be I can do advice based on the user feedback.
Thank you! I hope, I will do such section in the future. Currently let’s communicate here. Please create new topics if they are not related to the subject of the current topic.
MikhailModeratorThank you. I added this bug to the tracker.
Can you provide a screenshot?
Use styles:
colStyle="col-lg"
colStyle="col-sm"
colStyle="col-xs"
MikhailModeratorYou have a one input channel for a one tag.
Event must be bound to a tag that is bound to a channel to be passed to Server.
MikhailModeratorI can’t see important data on the screenshot, because it’s cropped. Can you find that file in C:\SCADA\ScadaComm\Log and paste it here?
Zindex is an order of components one above another when they overlap. Use it for moving back and forward.
MikhailModeratorCould you determine where the bug makes effect? Can you send email with that sign from Communicator?
MikhailModeratorCan you tell something more detailed about the configuration database?
It is difficult to specify the task for now. I am thinking about different approaches. May be we can store the configuration database in XML as a part of the project. It allows easily push it to Git and track changes. And we can use SQLite only for editing purposes as a temporary storage.
Contribution would be great! What do you think about development of a server module or a device driver? The API is mostly ready and will not be changes significantly. Do you familiar with mobile development? Many users ask for native mobile application. Also interesting are simple constructors for configuring that generate all the settings automatically.
Thanks for the question.Primary task for 2018:
– Create new components for schemes.Possible tasks for 2018:
– Update Chart Pro plugin. We need different Y axis, possibility to place graphs one above the other.
– Create module that automatically generates reports by a schedule and sends them by email.
– Develop the single configuration environment for Rapid SCADA that can manipulate with many projects, connect to remote server to download/upload configuration. It will replace Administrator, Server and Communicator shells.Future tasks:
– Update the structure of the configuration database. Get rid of MSSQL Compact.
– Make Server independent from a type of data storage.
– New drivers: OPC UA, BACnet, etc.-
This reply was modified 8 years, 3 months ago by
