MikhailModeratorThank you, this is useful info! OPC servers often work with tricks.
MikhailModeratorThank you.
MikhailModeratorWhat is your default Windows language?
MikhailModeratorUse SetCulture utility to change the application culture to en-GB.
Also you can click Настройки (5th) then Язык (2nd) and choose English.
Settings are applied after app restart.
MikhailModeratorShould it say “The channel is not defined” or something so?
Probably. In the next iteration of development of this module, we will take this into account.
Thank you, Sabas!
MikhailModeratorThat’s funny, but not a bug 🙂
I will write this behavior in our memories.
MikhailModeratorSCADA-Server stores data with milliseconds. You can find screenshots with Oracle DB here in the forum to check it. I think, the problem is in the version of MySQL. Could you try the actual version of MySQL on another PC?
You don’t need to create an issue on GitHub, because this forum is the primary site for issues.
This reply was modified 8 years, 1 month ago by
MikhailModeratorI will recommend OPC UA to our users 🙂
MikhailModeratorYou are welcome )
MikhailModeratorAll required files are located in the folders. So you can install services by executeingsvc_install.bat from command line as administrator.
MikhailModeratorScadaServer generated current data with the millisecond of timestamp are all zero.
What version of MySQL do you use?
Thank you for the solution. I suppose, that the wrong statement is in the queue and never can be skipped.
MikhailModeratorDo you have an idea in which case a sent value is changed to 0, and in which case it is saved correctly?
MikhailModeratorfor the command, you can only make boolean command on/off ?
Command of the Standard type has a value of double type.
Binary command allows sending any data.
MikhailModeratorRapid SCADA works as Modbus master, and it can be TCP server or TCP slave.
I still can’t open tcp connection with Local tcp port 502, error:The network connection was refused by the server.
You can use this Hercules utility to test connection.
