Viewing 15 posts - 4,591 through 4,605 (of 6,266 total)
  • in reply to: ElasticRep #4312
    It is possible to update the plugin and add an option that sets file name prefix. We can do it fast by a contract.
    Thank you for the idea. I suppose, this would be useful and I saved this idea in the internal ticket list for future implementation.
    • This reply was modified 7 years, 8 months ago by Mikhail.
    in reply to: OPC write value issue-IBH opc server #4311
    I need to restart the computer to use the server again.
    As I understand this is a temporary issue because of trial version of the OPC server.
    I am using Matrikon OPC to write Bucket brigade.boolean and Bucket brigade.int1 tags and works well. Also, i tried to write tags with QUICK CLIENT using IBH opc server and works well.
    Fixing of this issue is possible if a manufacturer of the OPC server agree to debug his OPC server with SCADA-Communicator. Can you contact the OPC developer?
    Do you have OPC UA option?
    in reply to: Users, roles, rights #4304
    Thank you. Be free to ask 🙂
    in reply to: "Unable to login : Server is unavailable" Problem? #4303
    2018-09-21 02:54:40 Error compiling the source code of the formulas:
    This message means that there is a problem in a formula of input channel. You should fix the formula and restart the Server service.
    See line 571 in C:\SCADA\ScadaServer\Log\CalcEngine.cs to find out what is the formula is incorrect.
    in reply to: Users, roles, rights #4299
    Users of the Guest role can view all. If you don’t want it, create your own custom role and apply it to the user named “guest”.
    in reply to: Rapid Scada sleep? #4298
    You should research what the services do when they not respond.
    Check logs of Server and Webstation.
    in reply to: Hysteresis on input channel… #4297
    Hi Josef,
    Other approach that may be easy to understand:
    1. Install Automatic Control Module and create triggers that will raise commands on your conditions. There are delays and deadbands available.
    2. Create an output channel and use SetVal() function to change a corresponding input channel.
    in reply to: I can not Activate Installed Plugins. #4296
    1. Try to delete WebSettings.xml.bak manually.
    If it doesn’t help:
    2. You should open properties of the C:\SCADA\ScadaWeb\config\ folder and allow read/write access to a user that is written in C:\SCADA\ScadaWeb\log\ScadaWeb.log
    I often provide access for all users, but this is not secure.
    Apply changes recursively.
    in reply to: "Unable to login : Server is unavailable" Problem? #4295
    Have you tried the above advice?
    What is written in C:\SCADA\ScadaServer\Log\ScadaServerSvc.log ?
    in reply to: Users, roles, rights #4286
    This is not necessary to add admin and guest to the Rights table. These roles are standard.
    The screenshots are clear. I didn’t catch what goes wrong? ))
    in reply to: OPC write value issue-IBH opc server #4285
    Writing issue: use Matrikon OPC to compare. If it works, the cause is related to the particular OPC.
    in reply to: OPC write value issue-IBH opc server #4284
    I need to restart the computer to use again the server
    Try restarting Communicator service.
    in reply to: Channel types description #4273
    1. Please open Administrator, open the Channel types table and find the descriptions.
    2. What is the context?
    In most cases, tag means variable in SCADA.
    3. Yes
    Link 1
    Link 2
    Link 3
    in reply to: Please advise Extra Scheme Components Plugin #4272
    Try unblocking PlgSchExtraComp.dll
    Example
    in reply to: Please advise Extra Scheme Components Plugin #4270
    Hi Phachakorn,
    Does ‘C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll’ file exist?
    What is the installation directory of Rapid SCADA? I suppose C:\SCADA\
    Note: Because your company purchased Extended support subscription, you also can solve issues by email or ticket tracker which is faster than forum. It’s up to you.
