Please advise Extra Scheme Components Plugin
Forum Home › Forums › Understanding the Software › Please advise Extra Scheme Components Plugin
  • #4258
    phachakorn
    I have installed Extra Scheme Components Plugin.
    But i can not see Extra Scheme Components in Scheme Editor.
    I have Activated in page plugin.
    #4261
    Please check the version of Scheme Editor.
    Also look the editor log for an error details.
    #4268
    phachakorn
    Hi Mikhail.
    Thank you for your advice.
    My name is Phachakorn
    I use Scheme Editor Version 5.2.2.0
    This is a message from Log file.
    2561-09-17 18:17:17 <PNT-PC><PNT><ACT> Initialize common data of Scheme Editor
    2561-09-17 18:17:17 <PNT-PC><PNT><ACT> Load components from files
    2561-09-17 18:17:17 <PNT-PC><PNT><ACT> Components are loaded from the file C:\SCADA\ScadaWeb\bin\PlgSchBasicComp.dll
    2561-09-17 18:17:17 <PNT-PC><PNT><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll:
    Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
    2561-09-17 18:17:17 <PNT-PC><PNT><ACT> WCF service is started
    2561-09-17 18:28:30 <PNT-PC><PNT><ACT> WCF service is stopped
    2561-09-17 18:28:30 <PNT-PC><PNT><ACT> Scheme Editor is shutdown
    What do I have to do Advise me.
    Thanks You.
    Phachakorn Tasusee
    Head of Automation Department
    Quick ERP Co., Ltd.
    #4270
    Hi Phachakorn,
    Does ‘C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll’ file exist?
    What is the installation directory of Rapid SCADA? I suppose C:\SCADA\
    Note: Because your company purchased Extended support subscription, you also can solve issues by email or ticket tracker which is faster than forum. It’s up to you.
    • This reply was modified 8 years, 1 month ago by Mikhail.
    #4272
    Try unblocking PlgSchExtraComp.dll
    Example
    #4274
    phachakorn
    It works.
    Solved the problem.
    Thanks for the quick advice.
