I can not Activate Installed Plugins.
Forum Home Forums Understanding the Software I can not Activate Installed Plugins.
  • #4291
    phachakorn
    Error saving web application settings: Access to the path ‘C:\SCADA\ScadaWeb\config\WebSettings.xml.bak’ is denied.
    How to fix?
    #4292
    phachakorn
    I use OS windows server 2012R2
    #4296
    1. Try to delete WebSettings.xml.bak manually.
    If it doesn’t help:
    2. You should open properties of the C:\SCADA\ScadaWeb\config\ folder and allow read/write access to a user that is written in C:\SCADA\ScadaWeb\log\ScadaWeb.log
    I often provide access for all users, but this is not secure.
    Apply changes recursively.
    #4306
    phachakorn
    It works.
    Solved the problem.
    Thanks for the quick advice.
