How to insert page break in Elastic Report (PDF)?
Where you’d like to insert page break?
The features you asked require additional development and update of the plugin. The most complex thing is that you need minute data in the report. Currently, the report uses hourly data only due to performance reason.
Could you provide a report example that you need?
We can discuss technical requirements here.
After we clarify all technical details, to get an offer contains the development cost, please write by email.Thank you.
MikhailModeratorPlease ask Marc why he doesn’t take into account the QualitySpecified field?
Mario, I’m interested in solving this issue. Let’s continue the dialog.
MikhailModerator5.5.3 version? I am using 5.5.2
The OPC driver was not changed.
MikhailModeratorAs I understand, quality is not specified.
Item 0:
vDataValue = VT_BOOL -1
bQualitySpecified = FALSE
wQuality = 0x0000 OPC_QUALITY_BADOctober 11, 2018 at 6:22 pm in reply to: Modbus TCP – One Element value gives 4 Digital Inputs, #4409
MikhailModeratorTry
GetBit(Val(100), 0) > 0 ? 0 : 1
where 100 is the number of the referenced input channel.
MikhailModeratorAdministrator->Settings->Language
Just type manually. It’s normal. After change here, restart IIS or restart the PC.
You should read this.
Also check ScadaWeb\log\ScadaWeb.log for additional information about the error.
MikhailModeratorWe can see the difference:
In the 1st example:
IOPCSyncIO::WriteIn the 2nd example:
IOPCItemIO::WriteVQTCan you ask the OPC server developer if they support IOPCItemIO::WriteVQT?
MikhailModeratorI think you should do step by step as shown in the videos.
Chart Pro plugin display existing data from a “minute archive”. Data are stored in this archive every 1 minute by default. If you set this parameter to 5 seconds by editing ScadaServerSvcConfig.xml, this may affect performance, because such value is not officially supported and tested.
MikhailModerator🙂
Communicator always uses the default formatting. You should set format in Administrator that works for the web app.October 9, 2018 at 3:11 pm in reply to: Modbus TCP – One Element value gives 4 Digital Inputs, #4369
MikhailModeratorOK. Let’s continue when you have a time.
Yes, you can.
1. Create 2 different xml files that define reports.
2. Add the appropriate records in the Interface table in Administrator as written in the manual.
MikhailModerator -
