Decimal Places in Elastic Report
Forum Home › Forums › Understanding the Software › Decimal Places in Elastic Report
  • #4366
    Boon Chang
    I am reading values of type double using OPC connection.
    The values appear at the communicator with 4 decimal places.
    I want to format the values to be of 1 decimal place.
    On the Webstation, I can display 1 decimal place by specifying format “D.D” in the Administrator.
    However, when doing report, it seems that the elastic report takes the values from the communicator straight and ignores the formatting in the Administrator.
    I have tried editing the xml file for the report, but am not sure what codes works, or if it is even a viable solution.
    #4368
    D.D only for displaying numbers. The database gets the full number
    #4370
    Communicator always uses the default formatting. You should set format in Administrator that works for the web app.
