Viewing 15 posts - 4,351 through 4,365 (of 6,279 total)
  • in reply to: MAP tile server #5022
    When you do it, please share your experience.
    in reply to: MAP tile server #5021
    Tiles should be available by a path like this
    https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png
    s – scale
    in reply to: MAP tile server #5020
    in reply to: MAP tile server #5019
    Definitely it is possible, but you need to do some research by yourself.
    The general sequence:
    1. Download tiles of the required area.
    2. Run local web server that provides tiles.
    3. Specify your local web server in a map XML file.
    in reply to: cannot find the file specified in ScadaWeb #5017
    i have a error similar #5010 when i built ScadaWeb
    Could you provide a link?
    Please describe what is expected behavior of the application and what is actual behavior?
    in reply to: formula input #5015
    Works like a charm but I’m limited to 100 symbols in formula input.
    To shorten, try this:
    public double OR(params int[] cnlNums)
    foreach (int cnlNum in cnlNums)
      if (Val(cnlNum) > 0 && Stat(cnlNum) > 0)
        return 1;
    return 0;
    Example of formula using is OR(1,2,3,4,5)
    • This reply was modified 7 years, 3 months ago by Mikhail.
    in reply to: formula input #5006
    Try the formula like that:
    public double OR(params double[] inputs)
    foreach (double input in inputs)
      if (input > 0)
        return 1;
    return 0;
    Note: I don’t test formulas on the forum. In case of error, please provide error message from the Server log.
    in reply to: export data to MS SQL #5003
    Try to find out what was changed in your system. Check SQL scripts in the module configuration.
    in reply to: Scheme Editor #5002
    I meant if you click a component in a list of available components. To cancel the selection, click a pointer.
    in reply to: Webstation day change #5001
    Many users ask for this feature. I suppose, we will implement it, but I can’t say when.
    in reply to: PenTest #5000
    You can deploy it on your server and perform penetration testing.
    in reply to: Scheme Editor #4995
    Click pointer if you need to deselect a component that is recently clicked.
    in reply to: Time Out #4994
    Try this recommendation.
    in reply to: Webstation day change #4993
    You need to manually select the next day. Would you like the application automatically switch a day?
    in reply to: Elastic Report and Chart Export function through iPad #4977
    Right now, the Elastic Report page is fully functional when viewed using iOS device.
    I am very glad. What application is used by iPad to open PDF and Excel?
    Do you have any idea how to address the issue of ‘Export’ option not appearing in the Chart window when viewed using iOS device?
    Open C:\SCADA\ScadaWeb\plugins\ChartPro\js\chartproform.js
    Find $("#hlExport").parent().addClass("hidden"); // hide Export menu item and comment or remove it.
