Forum Home › Forums › Uncategorized Issues › Time Out
- This topic has 6 replies, 3 voices, and was last updated 7 years, 5 months ago by
January 23, 2019 at 8:27 am #4934
Boon Chang
ParticipantDear Mikhail,
Is there a way to set or turn off auto-logout for which the RapidSCADA Webstation is left idle?January 23, 2019 at 1:42 pm #4936
You need to find a cause of logout. What operation system do you use? What is written in ScadaWeb.log when logout?
January 25, 2019 at 9:51 am #4945Boon Chang
ParticipantThank you for the reply.
I will look at Scada.log again when the automatic logout occurs.
At least now I know the existence of the log file.January 25, 2019 at 5:28 pm #4949
MikhailModeratorBy default, it is in C:\SCADA\ScadaWeb\log\
February 12, 2019 at 4:49 pm #4989bragofsky
ParticipantHello, I have the same issue,
How can I disable the auto log-out?
Here is an example of the log,
2019-02-07 17:38:50 <NAV-SMC-CO><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Refresh the tables of the configuration database
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Fill input channels properties
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Fill output channels properties
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Fill input channel statuses properties
2019-02-08 04:19:12 <NAV-SMC-CO><DefaultAppPool><ACT> Logout: admin. IP address: ::1
2019-02-08 04:19:12 <NAV-SMC-CO><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: ak1o4gxfw0ssrl5jqmf3kw2i
2019-02-08 04:19:12 <NAV-SMC-CO><DefaultAppPool><ACT> Application shutdownFebruary 13, 2019 at 1:34 am #4990Boon Chang
These are the logs:
2018-11-01 15:59:36 <HSAWA1><DefaultAppPool><ACT> Request SCADA-Server state
2018-11-01 15:59:36 <HSAWA1><DefaultAppPool><ACT> Disconnect from SCADA-Server
2018-11-01 15:59:36 <HSAWA1><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-11-01 16:03:20 <HSAWA1><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.1.13
2018-11-01 16:03:20 <HSAWA1><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.1.13. Session: xoj1xkbrtl1u0v1iggxyuf1x
2018-11-01 16:22:25 <HSAWA1><DefaultAppPool><ACT> Logout: admin. IP address: ::1
2018-11-01 16:22:26 <HSAWA1><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: vsftgrhhzjtelo0xq4s25fvc
2018-11-01 16:22:26 <HSAWA1><DefaultAppPool><ACT> Application shutdownAlso, the log file does not have events after that last entry even though I have been using the system. I think maybe the log file requires clearing to log new events.
February 13, 2019 at 2:54 pm #4994 -
