formula input
Viewing 12 posts - 1 through 12 (of 12 total)
  • #4982
    bragofsky
    Hello, with this formula Val(n) + Val(n), where n is the input channel, I managed to get my item working in 75%. All the conditions are working 0+0=0, 0+1=1 and 1+0=1, The only state that is missing is the 1+1=undefined. It’s supose to be 1 but I get nothing.
    Help please
    Regards
    #4983
    Judging by the logic you want to get logical OR ?
    Add formula to formula table
    public double OR(double in1, double in2)
    bool q = false;
    bool i1 = in1 > 0;
    bool i2 = in2 > 0;
    q = i1||i2;
    return Convert.ToDouble(q);
    Use in channel OR(Val (n), Val(m))
    • This reply was modified 7 years, 8 months ago by manjey73.
    #4985
    bragofsky
    Thanks for your reply,
    “Add formula to formula table” you mean the formula.dat or the calcengine.cs?
    #4986
    bragofsky
    Hello again, I already managed to edit formula table and it works great.
    For a logical AND, is the same?
    #4987
    Logical And
    public double AND(double in1, double in2)
    bool q = false;
    bool i1 = in1 > 0;
    bool i2 = in2 > 0;
    q = i1&&i2;
    #4988
    bragofsky
    manjev73, thanks!
    #5005
    bragofsky
    I have another issue
    I need to create a input to Station status to be showed in map, this input should behave like a or gate, my problem is with a OR formula in input channel, I can only put 2 inputs, when I put the third webstation stop’s working. I need to monitor 22 input’s to get the station status.
    The formula i’m using is “OR(Val(1001), Val(1002), Val(1003))” but server returns a error saying that OR cannot deal with 3 variables.
    #5006
    Try the formula like that:
    public double OR(params double[] inputs)
    foreach (double input in inputs)
      if (input > 0)
        return 1;
    return 0;
    Note: I don’t test formulas on the forum. In case of error, please provide error message from the Server log.
    #5007
    bragofsky
    Thanks Mikhail,
    Works like a charm but I’m limited to 100 symbols in formula input. Is there a way to add a range of input channels inside the OR gate formula?
    Another question, how can I change the value of an input? with a NOR?
    Regards
    #5008
    Divide formulas into several channels. If the formula returns double, you can use one formula inside another.
    for example
    NOT(OR(Val(100), Val(101)))
    public double NOT(double val)
        bool boolVal = val > 0;
        return Convert.ToDouble(!boolVal);
    #5009
    bragofsky
    Like a charm again… thanks Manjey73 and Mikhail.
    Have a nice weekend
    #5015
    To shorten, try this:
    public double OR(params int[] cnlNums)
    foreach (int cnlNum in cnlNums)
      if (Val(cnlNum) > 0 && Stat(cnlNum) > 0)
        return 1;
    return 0;
    Example of formula using is OR(1,2,3,4,5)
    • This reply was modified 7 years, 8 months ago by Mikhail.
