Viewing 15 posts - 3,886 through 3,900 (of 6,282 total)
  • in reply to: connection status #6309
    when some device logon or logoff
    How a device do this?
    in reply to: connection status #6308
    Each topic should describe only 1 question.
    Please create a separate topic for the second question.
    And provide examples for the both cases to make them clear.
    in reply to: Building the app error #6306
    Try removing ScadaWebCommon5 dependency. Does it help?
    in reply to: Automatic Control Module – Multiply triggers #6305
    You should create a time trigger as usual. Then in the output channel formula, check
    Val(101) < -10 ? Cmd : double.NaN
    double.NaN cancels the command.
    in reply to: Slave Device Failure #6304
    I’ve realized that the address must be added by 1 since rapidscada address starting from 1 and device address starting from 0.
    You can change the starting address in the template settings.
    in reply to: Device error: [02] ILLEGAL DATA ADDRESS! #6303
    in reply to: Device error: [02] ILLEGAL DATA ADDRESS! #6294
    1. “easy modbus client” – is this a library or an application?
    2. Talking about Comap: “It is possible to disable requiring the access code in
    the configuration web page.” It’s from the manual.
    3. We can update the existing Modbus driver to send access code as a custom development.
    in reply to: Get username for the schema editor. #6293
    I think, it’s possible to develop a plugin that writes user ID and username into specified input channels when a user logged in.
    If you are a developer, you can do it by yourself. Or you can order development.
    in reply to: Device error: [02] ILLEGAL DATA ADDRESS! #6288
    Could you provide an example of correct communication? I mean content of packets.
    Many controllers support disabling of protection by a code.
    in reply to: Get username for the schema editor. #6287
    No, sorry.
    If needed, I can research whether it’s possible to implement this feature by development a custom plugin.
    Anyway, an input channel may contain only 8 Latin characters.
    in reply to: Elastic Report – xml configuration #6283
    and now I can use more easily ElasticReport with the calcType=”Diff”
    Nice that simple solution is possible.
    Formulas like “=SUM(RC[-3]:RC[-2])” generated by Excel. It’s impossible for human 🙂
    in reply to: Help, command send now in Scheme Editor #6282
    You can set it in the formula of output channel in Administrator.
    For example, you can write a number there.
    in reply to: Building the app error #6278
    You should check the dependencies. There are no magic.
    in reply to: Building the app error #6276
    Log, ScadaCommCommon and ScadaData are located in the same repository. Build them before. Don’t forget to switch from Debug to Release configuration when build.
    in reply to: Mobile client and Rapid SCADA #6272
    The possible cause is the settings of network equipment.
    If Communicator works in the same LAN as SCADA-Server, I strongly suggest to specify Server IP address instead of DNS name. The important thing is that SCADA-Server opens TCP port 10000 for connection. It must be enabled on advanced settings of Windows firewall. In case you use DNS, it also must be allowed in the router settings.
    Have you checked the firewall and network equipment?
