MikhailModeratorNow i am going to configure a rapid scada to send commands from buton in the scheme. Can it? How to configure it?
You should watch this video.
MikhailModeratorCould you send communication line log again? Resize the application window to show more information.
What converter do you use to connect the module to a computer?
MikhailModeratorI suggest to follow the videos. If something is not clear in the videos, please ask a particular question.
MikhailModeratorOn the screenshot you can see that Modbus RTU is used. But in the settings there is Modbus TCP. Seems that the screenshots were made in different time with different settings.
What Modbus type is needed, Modbus RTU or Modbus TCP? What is written in the device manual about that?
MikhailModeratorDoes PAC3200 use Modbus protocol?
Could you make screenshots related to the issue?
MikhailModeratorDear Han,
Please follow the suggestions written by manjey73. In case of issues, put links to screenshots here.
MikhailModeratorWhat projects have you successfully built before facing the error?
MikhailModeratorYou should download the source code using the link I mentioned in this thread.
MikhailModeratorIs there an easy tutorial to learn how to use Rapid SCADA?
Does Rapid SCADA have the ability to obtain decimal numbers from 64 bit double precision registers
Yes.
What version of Rapid SCADA and Administrator do you use?
I don’t understand error messages in Chinese. Could you translate?
Check this topic. It may help.
MikhailModeratorPlease create a separate topic. This topic doesn’t match the questions.
Also provide an example that demonstrates how a system should behave.
MikhailModeratorThank you for finding the cause. I will fix it in the project.
MikhailModeratorFormula of output channel is calculated in a moment when a command is sent.
MikhailModeratorCan I use ‘Formulas’ also for this purpose?
What purpose?
Does it work in output formula field?
Such formula will work. But CustomFormula() == 1 …
