Add Device address
Forum Home › Forums › Communicating with Devices › Modbus › Add Device address
  • #6350
    joeh6966
    When I try to put in the Siemens Sentron PAC3200 address, the wizard asks for another integer, no matter how many I put in.
    So, is 192.168.1.103 an illegal address?
    Steep learning curve for me.
    #6351
    Siemens Sentron PAC3200 has an Ethernet port ? Some PLCs with an Ethernet port require you to also enter the address for the RTU network when connecting over Ethernet
    #6358
    Does PAC3200 use Modbus protocol?
    Could you make screenshots related to the issue?
    #6370
    joeh6966
    It has an ethernet port. I have been running Siemens Powerconfig for a couple of years successfully. Powerconfig has no logging capabilities.
    PAC3200 uses Modbus.
    I have a snip of the error message, but do not see how to post it.
    #6395
    To post screenshots, use https://imgur.com/
    #6403
    joeh6966
    Sentron PAC3200
    https://imgur.com/a/DmROorW
    • This reply was modified 6 years, 10 months ago by Mikhail.
    #6406
    The address must be an integer value, this is for the RTU Protocol. IP is entered in the call sign field
    Call number if I understand correctly the ratio of the English and Russian versions
    • This reply was modified 6 years, 10 months ago by manjey73.
    #6408
    The field is called “Call number” because it can be used for other purposes in some drivers. This is a common name. In the Modbus Protocol TCP is used for entering IP addresses
    #6410
    Enter 1 into Address and
    enter 192.168.1.103 into Call number.
