Is there an easy tutorial to learn how to use Rapid SCADA?
I only want to log one meter at least 4 times per day in one setup automatically, instead of manually like now. I have not been able to find any software that will make this an easy task.
One was Windmillsoft7 that doesn’t know how to convert 64 bit double precision registers to a decimal. So, if SCADA can’t do that, I don’t wish to waste any more time trying to get that simple task done.
Does Rapid SCADA have the ability to obtain decimal numbers from 64 bit double precision registers like the ones in the PAC3200?
Sorry, are you talking about the Siemens PAC3200 ? Yes, it has registers in double format, you just read a group of registers, and glue them together in Scada using formulas.
The current Modbus driver is able to work with Double directly
This reply was modified 6 years, 9 months ago by manjey73.
