The additional error information is in C:\SCADA\ScadaAdmin\Log\ScadaAdmin.err
Please provide the error details from the log.
MikhailModeratorMin and Max are constants. That’s true. As a work around you could create an extra input channel of the Calculated type. And set a formula to calculate some kind of relational value.
i would like the right picture, but the colors of the ring changing with time regarding a variable bandwidth.
The right picture uses a background found somewhere in the internet. A display over a gauge is a dynamic text component.
MikhailModeratorThe values in the table, also black, not red and green. This means that input channels are not configured properly. You should also set the Unit field to Off-On.
MikhailModeratorPlease contact us by email for more info.
MikhailModeratorCreate a table view to check color of values.
MikhailModeratorSorry, I mean:
Open Line 2 Parameters – Request Sequence, select the device 1 and then make a screenshot.
It’s possible to deploy a virtual machine in the cloud (Google, Azure, AWS, etc.) and install Rapid SCADA on that machine.
For our servers we use different providers. You should select your favorite.
MikhailModeratorDid you upload the project after change?
You need Automatic Control Module for this purpose.
MikhailModeratorChange channel type to Discrete
MikhailModeratorTimeout can be only be set to ‘System.Threading.Timeout.Infinite’ or a value > 0.
Please make a screenshot of the device properties in Communicator.
MikhailModeratorScreenshots would clarify the situation.
Please make screenshots of the input channels and the toggle properties.
MikhailModeratorError establishing TCP connection: No connection could be made because the target machine actively refused it 172.27.1.210:502
This message means that the PLC is not available by the IP 172.27.1.210 and port 502.
You should check the PLC.
Please provide a part of communication line log.
