Please make a screenshot of the Input channels table where we can see the mentioned channels.
This is a good idea. I also thought about this feature. Hope, we will find a sponsor to implement it.
MikhailModeratorI’ll open a new thread about this problem later.
OK.
MikhailModeratorUsing Moxa NPort, I prefer TCP server or TCP client mode.
If I were you, I would take the source code of KPSimulator and change it to generate values as needed. The HelloWorld project demonstrates how to use this driver.
As I know, free Matrikon OPC Simulation Server also generates different values.
MikhailModeratorThanks for noticing. In Linux file names are case sensitive.
Am I understand correctly? Draw marks (e.g. like little circles) over a graph corresponding timestamps of the existing events?
MikhailModeratorI strongly recommend OPC UA instead of OPC classic when possible
MikhailModeratorThis driver is not official, however, it exists. Updated link
Talking about the link 3, what did you do and what results did you get? Please provide more info.
MikhailModeratorSeptember 22, 2020 at 12:45 pm in reply to: How to set reading data to display on scheme or table #7301
You need:
1.1. Create a separate database that stores your data.
1.2. Or create at least a configuration file that stores your data.
2. Create a custom user interface that you have demonstrated.If you would like to discuss it in details, please create a separate topic.
We can develop that you need by a contract.
MikhailModerator3. Run the files
C:\SCADA\ScadaComm\svc_restart.bat
C:\SCADA\ScadaServer\svc_restart.bat
as administrator
1. Open the project in Administrator, open Instance Status and restart the services.
2. Open Windows service manager and restart the services. -
