This report is included in Chart Plugin which is installed by default.
What version of Webstation and Chart Plugin do you use?Also check existence of C:\SCADA\ScadaWeb\plugins\Chart\lang\PlgChart.en-GB.xml
and errors in C:\SCADA\ScadaWeb\log\ScadaWeb.log after computer restart.
MikhailModeratorHi Matt,
You can change it in ScadaData.*.xml
<Phrase key="ProductName">Rapid SCADA</Phrase>
MikhailModeratordoes the above update also applied for linux version?
Yes. It’s enough to update the *.dll files. ScadaServerMono.exe is just a shell to run the app.
Please provide a screenshot.
1. Yes, in the data panel there are only channel numbers.
2. Something wrong with a language file. What language do you use in Webstation?
This answer may help.
MikhailModeratorOK
To debus a DLL, you need to attach to the process that uses the DLL. In case of drivers, attach debugger to ScadaComm.exe
February 10, 2021 at 2:17 pm in reply to: Cannot see installed schemes extra components module #8281
Probably the access rights return to defaults when you upload the project. I suggest editing web app settings via XML file in Administrator. In the future all settings will be edited using Administrator UI.
You should set
~/View.aspx?viewID=33~ means root.
February 9, 2021 at 1:13 pm in reply to: push data to third-party station or another rapid scada station #8277
MikhailModeratorThe latest version of Rapid Gate includes user interface. If needed, I can help to fix related issues.
1. You need to unblock KpTelegram.dll
2. To open communication line log, click the Line Stats node and then select Line Log. All Communicator log files are located in C:\SCADA\ScadaComm\LogFebruary 8, 2021 at 1:55 pm in reply to: push data to third-party station or another rapid scada station #8273
MikhailModeratorFor what module do you need the utility?
MikhailModeratorAlso you can find a computer code in the communication line log.
To restart the Communicator service, in Administrator click the Instance status button on the main toolbar, and then click the Restart button.
