Forum Home › Forums › Understanding the Software › ChartPro Export to Excel
- This topic has 13 replies, 2 voices, and was last updated 5 years, 6 months ago by
Rich Ex.
February 16, 2021 at 12:09 pm #8290
Rich Ex
ParticipantHi Again ,
Im using ChartPro with a view to buy and firstly thanks for answering my previous question about it .
I have the trial key and have been using ChartPro and it displays what I need fine .
I have read the documentation on ChartPro but am now stuck !
Couple of questions about the ChartPro in Webstation.1. When I ‘show data’ from the 3 bars menu tab the data is shown with only the channel numbers ,am I able to show the channel name here ?
2. When I export to ‘excel’ , I can open the file in Libra Office Calc but the columns are shown as [ValColTitle] , is this something I have missed in a setting somewhere .As always thanks for a great piece of software .
RichFebruary 16, 2021 at 4:06 pm #8291
1. Yes, in the data panel there are only channel numbers.
2. Something wrong with a language file. What language do you use in Webstation?February 17, 2021 at 9:04 am #8294Rich Ex
ParticipantHi Mikhail ,
In Webstation I had the ‘Application Parameters’ ‘Culture’= “” at first , I have now changed them to “en-GB” as I am British , but the excel file is still showing the column headings as [ValColTitle].Thanks
RichFebruary 17, 2021 at 1:51 pm #8295
Please provide a screenshot.
February 18, 2021 at 9:34 am #8298Rich Ex
Here are the screenshots of the 2 files .https://ibb.co/S7jxNKs
https://ibb.co/L63sRS2Thank you
RichFebruary 18, 2021 at 4:02 pm #8300
This report is included in Chart Plugin which is installed by default.
What version of Webstation and Chart Plugin do you use?Also check existence of C:\SCADA\ScadaWeb\plugins\Chart\lang\PlgChart.en-GB.xml
and errors in C:\SCADA\ScadaWeb\log\ScadaWeb.log after computer restart.February 19, 2021 at 9:08 am #8303Rich Ex
C:\SCADA\ScadaWeb\plugins\Chart\lang\PlgChart.en-GB.xml YES exists as does the en-GB file in the Chartpro folder.Here is the latest from the ScadaWeb.log … as you see I’m using Chartpro to generate the Excel files…
Registration key is valid. Expiration date is 20/02/2021
Computer code: =0AAB8F2568031BE8-62CD277682F0E4D0-D53E5B16E5CE474F-66A5C6A3327FDFAC-63BD67BC4DDCAB88-630AE59F4EBCA807-5EC21FE4FB7E503E-C4F6F90346DA6721=
2021-02-19 08:56:56 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:57:10 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:57:10 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:57:23 <V-SCADA-01><DefaultAppPool><ACT> Generate “Minute data” report by the user admin
2021-02-19 08:57:23 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:57:23 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:58:11 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:58:11 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:59:12 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210219.dat
2021-02-19 08:59:12 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210219.datThank you
RichFebruary 19, 2021 at 1:27 pm #8305
Restart web server, open a report, and copy all lines from the log starting from
“Initialize common web application data”February 19, 2021 at 1:27 pm #8306
MikhailModeratorWhat version of Webstation and Chart Plugin do you use?
February 22, 2021 at 10:48 am #8308Rich Ex
ParticipantHi , date as requested ,
2021-02-22 09:36:40 <V-SCADA-01><DefaultAppPool><ACT> Application shutdown
2021-02-22 09:42:26 <V-SCADA-01><DefaultAppPool><ACT> Initialize common web application data
2021-02-22 09:42:26 <V-SCADA-01><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2021-02-22 09:42:26 <V-SCADA-01><DefaultAppPool><ACT> Refresh the tables of the configuration database
2021-02-22 09:42:27 <V-SCADA-01><DefaultAppPool><ACT> Fill input channels properties
2021-02-22 09:42:27 <V-SCADA-01><DefaultAppPool><ACT> Fill output channels properties
2021-02-22 09:42:27 <V-SCADA-01><DefaultAppPool><ACT> Fill input channel statuses properties
2021-02-22 09:42:27 <V-SCADA-01><DefaultAppPool><ACT> User information has been added. IP address: 10.1.0.99. Session: qcgpwkn51mr3xi3y5frj3wsi
2021-02-22 09:42:28 <V-SCADA-01><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 10.1.0.99
2021-02-22 09:42:28 <V-SCADA-01><DefaultAppPool><ACT> User information has been updated. IP address: 10.1.0.99. Session: qcgpwkn51mr3xi3y5frj3wsi
2021-02-22 09:42:28 <V-SCADA-01><DefaultAppPool><ACT> Retrieve components from the installed plugins
2021-02-22 09:43:08 <V-SCADA-01><DefaultAppPool><ACT> Logout: admin. IP address: 10.1.0.99
2021-02-22 09:43:20 <V-SCADA-01><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: drmo402hd3wl2rac0fue5auy
2021-02-22 09:43:27 <V-SCADA-01><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
2021-02-22 09:43:27 <V-SCADA-01><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: drmo402hd3wl2rac0fue5auy
2021-02-22 09:43:27 <V-SCADA-01><DefaultAppPool><ACT> Retrieve components from the installed plugins
2021-02-22 09:43:46 <V-SCADA-01><DefaultAppPool><ACT> Check “Chart Pro” registration:
Registration key is valid. Expiration date is 23/02/2021
2021-02-22 09:43:46 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210222.dat
2021-02-22 09:44:10 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210222.dat
2021-02-22 09:44:10 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210222.dat
2021-02-22 09:44:10 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 257 trend from SCADA-Server. File: m210222.dat
2021-02-22 09:44:32 <V-SCADA-01><DefaultAppPool><ACT> Generate “Minute data” report by the user admin
2021-02-22 09:44:32 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 218 trend from SCADA-Server. File: m210222.dat
2021-02-22 09:44:33 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 213 trend from SCADA-Server. File: m210222.dat
2021-02-22 09:44:33 <V-SCADA-01><DefaultAppPool><ACT> Receive input channel 257 trend from SCADA-Server. File: m210222.datVersions are , Webstation = 5.1.2.0
Chartpro = 5.1.0.1I only have Libra office not MS Excel , is this an issue ?
RichFebruary 22, 2021 at 2:49 pm #8311
MikhailModeratorHi Rich,
No. The cause is in Rapid SCADA.
Please open a list of installed plugins and check that Chart Plugin (not only Chart Pro) is also active. It is important to load phrases from PlgChart.en-GB.xml
February 23, 2021 at 9:02 am #8312Rich Ex
You are correct Chart Plugin was deactivated , not sure why, I had not changed it ?
It is now showing the channel numbers in the Excel report , thank you so much.Final point with this question I see you can make custom report requests with chart Pro can you have it so the Excel files shows the channel name or is it like the on screen ‘data’ field and just shows the channel number .
Thanks again
RichFebruary 23, 2021 at 11:24 am #8314
Changes of the report are possible, but require custom development.
February 24, 2021 at 2:54 pm #8319Rich Ex
So looking at a custom report I would need to start by looking at the MinDataRep file for Chart and Chartpro , I will share with the forum if I can make it work .Thanks
Rich -
