Viewing 15 posts - 3,211 through 3,225 (of 6,289 total)
  • in reply to: Custom Page #8376
    Use getCurCnlDataExt function. If you run file search of “getCurCnlDataExt” on *.js files, you will find examples in the Table and Scheme plugins.
    in reply to: Export to SQLite #8375
    SQL requests are executed by the module every time when data are sent from Communicator to Server. So the logic to store data with particular interval should be implemented on the DB level.
    However, in 2021 we plan to release an update of DB export module to be able to upload Rapid SCADA historical archive to a DB. This feature may be useful in your case.
    in reply to: rapidgate module bug #8374
    Also needed C:\SCADA\ScadaServer\Log\ModRapidGate.log
    I’m sure, this issue can be fixed, and I’ll help to do it.
    in reply to: OPC no values #8373
    I can help you if you provide remote support for the OPC server for testing. Is it possible?
    in reply to: Modbus RTU comunication issue #8372
    Please provide screenshots of the communication line settings and log with errors.
    in reply to: l #8358
    Question:configure the link component, the second-level dialog box does not display data, and no pop-up box appears when the button is clicked.
    Please make a screenshot of the dynamic text properties that is located on the popup. Did you set the Input channel property of this component? It’s required to show values.
    there is something wrong…
    The question is duplicated.
    in reply to: Scada Agent error #8356
    Try repeating the installation steps related to the web application.
    in reply to: Export to SQLite #8355
    I think you should choose one of the native supported databases.
    in reply to: Export to SQLite #8354
    DB Export Module natively supports MySQL, PostrgeSQL, MS SQL and Oracle.
    There is a chance that it’s possible to use Sqlite with help of OLE DB provider. To check it, you need to try setup a connection by Server Explorer of Visual Studio and then copy a connection string.
    in reply to: rapidgate module bug #8353
    Parameter name: format
    It is related to string formatting. May be language files were not loaded and a required string is empty. Anyway, log files are needed.
    in reply to: rapidgate module bug #8352
    Please provide bigger part of ScadaServerSvc.log and ModRapidGate.log which are located in C:\SCADA\ScadaServer\Log
    in reply to: get line state #8351
    Currently, getting line and device state is not supported. You need some workaround.
    It can be a good idea for the future.
    What information do you need to extract?
    i use gate module to send data between them
    Rapid Gate was updated on December 14, 2020. Do you use the latest version?
    i write an big screen project to show tcp state and line state.
    Could you share screenshots?
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #8336
    in reply to: Server is unavailable #8335
