Forum Home › Forums › Understanding the Software › Formulas › get line state
- This topic has 4 replies, 3 voices, and was last updated 5 years, 9 months ago by
February 27, 2021 at 3:42 am #8339
ZeusParticipanthi Mikhail
i am trying to get the communication line state and send it to input channel,so that i can record event on change to let user know the communication line state through the web platform ant let user konw when was the time that device went Idle or Terminated. it confused me for three days,could you help me how can i make it work, thanks a lot.February 28, 2021 at 9:55 am #8342
ZeusParticipanthi
i have an idea. i will write a kpdriver to analysis the commonsvc log file and send the status to input channel. it would help me solve my problem.
is that good ahahaMarch 1, 2021 at 6:56 am #8345JW
ParticipantHi, I used the following work around.
Line 1
|–Device 1
|–Device 2Added extra channels as temporary data
InCnl 10101: Signal 1 of device 1, real, Line 1 Device 1 Stat
InCnl 10201: Signal 1 of device 1, real, Line 1 Device 1 Statadd extra channel to monitor status
InCnl 101: stat(10101), Calculated discrete, Line 1 Device 2 Stat (O means offline, 1 online)
InCnl 102: stat(10201), Calculated discrete, Line 1 Device 2 Stat (O means offline, 1 online)
InCnl 100: Stat(10101)+Stat(10201)==0?0:1, Calculated discrete, Line 1 Stat (O means offline, 1 online)then enable event on change of these 3 channels, to log event of online/offline
** assuming all device offline = communication line offline.
you can miniplate formulas to have more states as you needed
March 1, 2021 at 7:58 am #8349
ZeusParticipantit is a good idea thanks
but it will cost plenty to config input channel.
i write a kpdriver to analysis the commonsvc log file and a send status to inputchannels there are four states.you can see it in project code.
i use a master server and many slave servers in a large project. i use gate module to send data between them.
i also write a kpdriver to monitor the tcp status between servers.
i write an big screen project to show tcp state and line state.March 1, 2021 at 8:28 am #8351
Currently, getting line and device state is not supported. You need some workaround.
It can be a good idea for the future.What information do you need to extract?
Rapid Gate was updated on December 14, 2020. Do you use the latest version?
Could you share screenshots?
