MikhailModeratorYou can see minute data in the Chart Pro panel, and you can export minute data to Excel if you open the Reports page.
September 15, 2022 at 9:29 am in reply to: How to add Chartpro plugin and use it in Rapid Scada version 6 #10764
MikhailModeratorI’m glad that the issue has been solved!
MikhailModeratorAs I understand, you read the registers correctly, right?
MikhailModeratorAccording to the screenshots, the registers starting from R1 are not bound to input channels. You can see that Channel cells for them are empty. You need to create input channels in the Input channels table with proper Signal field (9…18).
When you create channels using the wizard, all channels will be created. If you need to add a few channels, you can do it manually.
A screenshot of the Input channel table may be helpful.
MikhailModeratorThis forum is in English. The above link is just a copy of the official manual.
MikhailModeratorClick the Reports menu item to export data. This issue has no relation to Modbus.
MikhailModeratori am new on Linux
In this case I suggest using Ubuntu if you are not obliged to choose CentOS.
You can use forum in Russian https://forum.rapidscada.ru/ if it is more comfortable.
MikhailModeratorWhere did you find the protocol specification?
MikhailModeratorYou should add the formulas into the Formulas table. Then upload configuration to check if it still works. If OK, set formulas to input channels as written here.
September 13, 2022 at 8:47 am in reply to: How to add Chartpro plugin and use it in Rapid Scada version 6 #10735
MikhailModerator@afp , the update works on my computer. I just copied that files from it.
Could you try to install Rapid SCADA 6 and Chart Pro on Windows 10/11 machine and use a temporary key for testing?
MikhailModeratorIf you mean that you need an average of all datapoints between 3 and 4am, you should use averaging formulas in the configuration database.
MikhailModeratorCould you provide screenshots?
Can I use the other text
Yes. You can change ProductName in the language file C:\SCADA\ScadaWeb\langScadaData.xx-XX.xml
Does the Server app use TCP port 10000 to communicate with clients? It looks like Server can’t open the TCP port. May be it is in use by other service.
Good 🙂
I suggest using this instruction to resolve your task. -
