Help to install Rapid SCADA on Linux Cent OS 7
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Help to install Rapid SCADA on Linux Cent OS 7
  • #10742
    elviz
    Hello everybody i want install Rapid SCADA on CentOS7 but i can’t find normal documentation. Samebody can help me too instal.
    #10744
    You probably need to redo the startup scripts, since they are written for Debian-like systems. Otherwise, there probably shouldn’t be any problems, since the entire system can be simply copied.
    #10746
    elviz
    thank you answer but now it is my first practices and i find same documentation on Ubunto. For Debian i can’t find.
    #10748
    elviz
    i am new on Linux to and i can’t run this comment on linux CentOS
    maybe this not for linux CentOS.
    sudo apt install apt-transport-https dirmngr gnupg ca-certificates
    sudo apt-key adv —keyserver hkp://keyserver.ubuntu.com:80 —recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
    echo «deb https://download.mono-project.com/repo/debian stable-stretch main» | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
    sudo apt update
    #10750
    apt install These are the commands of Debian, and distributions based on it
    If you are new to Linux , then why did you grab CentOS ? The illusion of freedom? 🙂
    #10751
    For CentOs
    You will have to choose whether to look for solutions for CentOS or take the easier path. But there are always solutions.
    #10754
    i am new on Linux
    In this case I suggest using Ubuntu if you are not obliged to choose CentOS.
    You can use forum in Russian https://forum.rapidscada.ru/ if it is more comfortable.
