Viewing 15 posts - 1,831 through 1,845 (of 6,266 total)
  • in reply to: set button #12460
    The existing button component has no state. To achieve this, a new component should be developed. This is not common behavior for controls on web pages, because tap is usually used for displaying a popup menu.
    in reply to: REST API for the RapidScada #12454
    Thank you for the code.
    If you publish your application to Google Play, please let us know.
    in reply to: REST API for the RapidScada #12450
    By the way, could you share info about your application? Is it web or mobile?
    in reply to: REST API for the RapidScada #12449
    To solve the issue, try handling cookies. Please check this example.
    in reply to: Web API, REST API, version 6 #12448
    I try to get and write data from Rapid Scada, but it’s not working the response statusCode is 401. how can I solve it?
    Will reply here.
    in reply to: Remote Webstation #12446
    Probably, you don’t need to change settings in Chrome.
    Instead of turning firewall off, create a rule for incoming connections and allow TCP port 10000.
    To check if port is available run the command on the client PC
    telnet SERVER_IP 10000
    You need to activate Telnet Client.
    • This reply was modified 3 years, 1 month ago by Mikhail.
    in reply to: Chart not Displaying Data #12445
    What language is set in the Administrator app – Tools – Language?
    Try generating an Excel report for channel 4101 to check channel data.
    in reply to: modbus transfer string value #12444
    Why don’t you do the following:
    1. Set the default by order 01234567
    2. Get string as is.
    3. Draw tables with the expected and actual strings. Draw arrows from one table to another to find proper byte order.
    in reply to: Webstation error #12443
    Could you create a new topic please? Sorry for the inconvenience.
    in reply to: Auto Report #12435
    Hi Roxy,
    Will it be possible to just automatically save reports on a designated folder without emailing it?
    Yes, there is an option for this.
    I already have a license for Elastic Report, do i still need auto report for auto generation ?
    Auto Report requires it’s own license, because it’s a different application that adds useful features. The Auto Report app does not need Elastic Report key for generating reports. But’s it’s more comfortable when you have the both licenses, because web plugin Elastic Report is handy for development reports, and sometimes a user needs report in time.
    in reply to: modbus transfer string value #12433
    1. Copy the valid variable name from here: ArrIdx
    I and l are different characters.
    2. Find the appropriate byte order.
    in reply to: Webstation error #12432
    The topic called “Webstation error”, but the error is displayed in Communicator. You should check the Communicator log file.
    in reply to: DrvDbImportPlus ERROR #12423
    Probably the error is caused by version mismatch.
    Check the current version of SCADA\ScadaAdmin\ScadaCommCommon.dll
    in reply to: modbus transfer string value #12422
    Byte order is set in the template options https://ibb.co/9wWZHG4
    Could you make a screenshot of the settings and the error?
    in reply to: Webstation URL #12421
    The last question is off topic. Please post in the appropriate thread.
