Remote Webstation
Forum Home Forums Runtime Bugs Webstation Bugs Remote Webstation
  • #12440
    Bang
    Im currently working on this architecture:
    Server is located on an Engineering station, then there’s a separate location for the operator’s workstation, which is the Client PC.
    I installed everything on the Server, while only installed webstation for the Client.
    I have trouble accessing Sever IP Address on Client PC browser. Note that communication between server and client PC is established (thru ping).
    May you suggest the next step? Maybe I missed something on Server parameters.
    The following are what Ive tried:
    1. I’ve tried allowing settings on Chrome Settings.
    2. Turned Firewall Off
    Thanks in advance
    #12446
    Probably, you don’t need to change settings in Chrome.
    Instead of turning firewall off, create a rule for incoming connections and allow TCP port 10000.
    To check if port is available run the command on the client PC
    telnet SERVER_IP 10000
    You need to activate Telnet Client.
    • This reply was modified 3 years, 3 months ago by Mikhail.
