Viewing 15 posts - 1,396 through 1,410 (of 6,288 total)
  • in reply to: Data Exporting #13723
    The above is the content of ScadaServer.log
    Log files of the module are ModDbExport*.* in the same directory.
    • This reply was modified 2 years, 6 months ago by Mikhail.
    in reply to: Login Rapid from other PC #13722
    If you use Windows, create a rule to allow incoming connections to the port 10008 in the Windows firewall.
    in reply to: V5 and V6 installation #13721
    Ports for v5 are kept by default.
    For v6:
    – Set Agent port in SCADA\ScadaAgent\Config\ScadaAgentConfig.xml Then restart the service.
    – Set ScadaServer port using the Administrator app.
    – Update Communicator and Webstation connection options.
    – Update the deployment profile in the project.
    in reply to: Update from 5.8.3 to V6 #13720
    Please provide a screenshot.
    in reply to: Creating Relevant Animations #13713
    on page 1 I created a button which when pressed will move the display to page2.sch
    It’s possible with a Link component.
    can the scheme create a pie chart?
    Integrate Rapid SCADA and Grafana for this purpose.
    For more details, please create new topics, because this topic is about animation.
    in reply to: V5 and V6 installation #13712
    If you need v5 and v6 running in parallel, you should use different TCP ports for the Agent and Server apps.
    It is easier to stop the services of v5 before running v6 and vice versa and use the default TCP ports.
    https://ibb.co/9hMpGGQ
    in reply to: Creating Relevant Animations #13709
    Please explain what is moving the page?
    in reply to: Update from 5.8.3 to V6 #13708
    Please check this topic.
    in reply to: String dynamic text change according input channel value #13704
    Unit 40 includes 2 strings: Normale and Esaurito.
    Normale = 0.
    Esaurito = 1 or higher.
    – Using formulas you should convert channel values to 0 and 1.
    – It’s impossible to bind 2 channels to one tag. Change channel’s 11 type to Calculated, delete it’s Signal, and set it’s formula to something like Val(10) < 50 ? 0 : 1
    in reply to: Issues and Error Handling When Starting a SCADA Project #13703
    Full class name of DrvUdpView must be as written in the error message. You should change the namespace to meet the requirements.
    in reply to: Data Exporting #13696
    If the module is active, check it log files.
    in reply to: Hide Events #13695
    Try restarting the IIS service or restarting the computer.
    in reply to: Creating Relevant Animations #13692
    GIF images are compressed, so they usually not heavy.
    in reply to: Creating Relevant Animations #13691
    For example this GIF is about 1 MB. I expect that your file should not be as large as 100 MB.
    in reply to: Issues and Error Handling When Starting a SCADA Project #13690
    To run Rapid SCADA *dll, *.xml and other files should be in proper locations.
