Viewing 15 posts - 6,256 through 6,270 (of 6,270 total)
  • in reply to: SCADA-Administrator Output channels #87
    Thanks for Number in Russian issue. It will be fixed.
    in reply to: SCADA-Communicator Device Libraries #86
    Modbus, OPC and AT commands are commonly used worldwide.
    VKT-4M, etc. are specific for Russian customers, therefore they were excluded from the installation package to keep the product clear.
    in reply to: Device template #85
    A Modbus element which is read from a device has Signal field. SCADA-Communicator receives data from a device and retrieves an input channal number using Device number and Signal, then SCADA-Communicator passed data to SCADA-Server.
    A Modbus element which is written to a device has Command number field. When you send a command, you use a specified output channel, so SCADA-Communicator chooses the appropriate command by Device number and Command number which are defined in the output channel.
    in reply to: Dupliacated Output channels – ADAM-6015 Server room #84
    It is strange. My configuration database contains only 11..14 channels.
    I think you can delete 1..4 channels.
    in reply to: SCADA-Administrator Output channels #83
    Hello Teleco,
    1. Number is internal. It is needed for associating different information with a command.
    2. Command number is sent to SCADA-Communicator when you send a command. It is processed by device driver. For example, you can bind Modbus command to a specified command number from the configuation database. Comamand number field is similar to Signal field.
    3. If Command values field in Output channels table is not set you can directly input a value of command. If it is set the value of command is an index of the selected list value. Often you need to convert value according to device specification using formula of output channel.
    in reply to: SCADA-Administrator input Channles #81
    1. To simulate “ADAM-6015 Server room” do not modify anything in Rapid SCADA configuration. Just tune up the simulator according to KpModbus_Adam6015.xml template. 101 is internal channel number for Rapid SCADA. In Modbus terms t4 is an element with address 5 from Holding Registers (4x) data table.
    2. Calculated Real type is set for a channel if its formula refers to data of other channels. Use Real type if channel data is received from a device.
    3. Signal binds an input channel to a tag of device. This field is processed by SCADA-Communicator.
    4. The items t4_min, t4_max, t5_min, t5_max display data and allow sending commands. Each item of table view can hold either input or output channel. Channel numbers are written in item’s hint. Commands are sent manually in this example.
    • This reply was modified 11 years, 4 months ago by Mikhail.
    in reply to: Modbus simulator #80
    I’ve tried the same as you did.
    Call numbers localhost and computer name don’t work, because of wrong IP address format.
    Call number 127.0.0.1 is OK:
    2015-02-01 21:57:56 Communication session with Device 11 “ADAM-6015 Server room”, type: KpModbus, call number: 127.0.0.1
    Establish a TCP connection with 127.0.0.1
    During testing I uncheck “Use SCADA-Server” checkbox in SCADA-Communicator. If you do not uncheck it the call number specified in the configuration database is used.
    Try 127.0.0.1 again. If it doesn’t work post a part of log here.
    in reply to: Modbus simulator #72
    Switch to Communication Line log tab.
    Read the log carefully, usually it contains information about the cause.
    Firstly, realize is the connection established or not.
    in reply to: WCF Service error #71
    The error is concerned with a security reason. Scheme is displayed by the silverlight application which can’t connect to WCF service.
    Try to open SCADA-Web using different URLs:
    http://localhost/scada
    http://127.0.0.1/scada
    http://YourComputerName/scada
    Does it solve the problem?
    in reply to: Users and passwords #70
    The system works exactly as you described. It is not a bug. The goal of the passwords in SCADA-Server shell and SCADA-Communicator shell is let a user think for a few seconds before sending data or command.
    It is proposed that the user who has administrative rights on a server required to start SCADA-Server and SCADA-Communicator is accepted to control SCADA.
    in reply to: Scada Server connection problemes #66
    Of course you can add new users and modify the existing.
    Try to do a one modification and if the system works strangely post a question to Understanding section with description of changes and symptoms.
    Could you make a separate topic about WCF service error?
    in reply to: Data simulation #65
    Dear Teleco,
    Probably you didn’t modify status of sent data using Generator. Set status >= 1 to display the value in SCADA-Web.
    Anyway you are able to control sent value and status directly in the archive files those can be opened by SCADA-Server.
    SCADA-Communicator “doesn’t know” about values sent by Generator. It dispays error if no connection with device has been established.
    in reply to: Scada Server connection problemes #61
    I think you should restore User table in the configuration database. Do the following:
    1. Open SCADA-Administrator and make a backup of the configuration database.
    2. Clear all the data from Users table.
    3. Unzip user.dat from ScadaAdmin.zip of the installation packege and overwrite the existing file.
    4. Import user.dat into the configuration database.
    5. Restart SCADA-Server.
    Open http://localhost/scada and try to connect as: admin
    Default password: 12345
    in reply to: Scada Server connection problemes #59
    Did this issue appear just after the installation of Rapid SCADA or after configuring?
    If you make some changes using SCADA-Administrator before the problem occurs please describe them.
    “http:\\127.0.0.1 in browser bar it shows me the IIS8 initial site” – it’s OK.
    in reply to: Installation errors #56
    Dear Akbarm,
    Please post the following additional information about the issue:
    1. What were the errors occured during installation?
    2. What is the state of SCADA-Server when it runs? The state is written in C:\SCADA\ScadaServer\Log\ScadaServerSvc.txt
    This issue often appears if some other application uses TCP port 10000. For example, torrents client. In this case, close that application and restart SCADA-Server service.
