Users and passwords
Forum Home › Forums › Understanding the Software › Users and passwords
  • #67
    teleco
    I have changed all the passwords in SCADA-Administrator -> Users, but anyway, if I want to send some data, events or commands in SCADA-Server -> Generator, the valid password is the default password 12345. The same occurs in SCADA-Communicator -> Line 1 “Server room” -> Device 11 “ADAM-6015 Server room” -> Commands (the same to OPC and GSM lines). However, in SCADA-Communicator -> Common parameters the password seems to be changed to the new because I have no problems for connecting to SCADA-Server. The passwords of the default users admin, guest, Smith and jones have been changed succesfully too, verified in SCADA-Web.
    Why in some cases the password still continue being the default password 12345? How can I change it?
    #70
    The system works exactly as you described. It is not a bug. The goal of the passwords in SCADA-Server shell and SCADA-Communicator shell is let a user think for a few seconds before sending data or command.
    It is proposed that the user who has administrative rights on a server required to start SCADA-Server and SCADA-Communicator is accepted to control SCADA.
    #4426
    look this
    • This reply was modified 8 years, 1 month ago by manjey73.
