manjey73ParticipantThis is disabled in Mono because it does not work correctly. Therefore, there are ids of other tables instead of a list. We hope that in the next version, if you abandon Mono, everything will be fine.
manjey73ParticipantThe signals and have a fixed numbering, but based on the indexes of the list of variables. And since we can change the lists, then what happens is what happens 🙂
This reply was modified 4 years, 9 months ago by
manjey73.
manjey73ParticipantYes, this is a drawback of the Modbus driver and many others related to the tag generation code from the driver. I had to get away from this and look for a workaround by adding a mechanism to the code of my drivers to save the signal numbers that I want to see. As a result, I can disable or add variables without touching the signal numbering. For freely programmable devices, this is the first necessity. Yes, in other things, and for configurable ones, too.
It is hoped that the developer will listen to this problem and make some changes, at least in the Modbus driver.
manjey73ParticipantYou pass the value of the channel itself in the command, and you need to pass Cmd or CmdVal, that is, the value of the command
manjey73ParticipantSetVal(5050, Cmd)
I’m confused, do you call your application Scada ?
This reply was modified 4 years, 10 months ago by
manjey73.
manjey73ParticipantAdd this value to the input channel and display it in a table or diagram
manjey73ParticipantA formula in the reference list with an enumeration for example
manjey73ParticipantUse the Elastic Report Plugin it can be set to the hourly version. But of course I would like to have such an opportunity in ChartPro
manjey73ParticipantChartPro takes data from the minute slice and is not yet able to show the chart and export it in hourly format
manjey73ParticipantTo fill the tanker, you must have reserved PLCs and I / O modules for critical tasks. This is not a Scada function. Think about security first. It is not necessary to burden the software with something that does not belong in it. I apologize for my English, I use an online translator
manjey73ParticipantYou can synchronize the time to achieve parallel polling by two Scada systems, by separating the polling time. I have already tested this on RS485 lines, it works. There may be collisions when restarting the server since the initial poll is performed immediately
manjey73ParticipantWhat Event Log are you talking about? built-in or optional from the repository ?
manjey73ParticipantUse RapidGate it seems to be designed for this purpose. Or are you interested in hot swapping on the fly ?
manjey73ParticipantBut to work with GPIO, you will most likely have to write a driver specifically for this PC.
