Forum Home › Forums › Communicating with Devices › Modbus › Communicator will be stoped after Upload Configurations
- This topic has 8 replies, 3 voices, and was last updated 5 years, 6 months ago by
May 23, 2021 at 2:30 pm #8989
xdwokcn
ParticipantWhen I finished my configuration and upload it to the server ,I find that serveral minites later, the communicator has been stopped , I must open the ScadaAdmin to restart the communicator, and after I start the conmmunicator, it works well.
so, this problem is why the communicator automaticlly stoped after uploading the configuration to server.
I have update the software to the latest version, and my OS is Windows Server 2016.
May 23, 2021 at 3:04 pm #8990xdwokcn
ParticipantI have checked the log, I find that during I upload the configuration to the server ,the communicator cannnot connect to the ScadaServer, but the scadaServer service has been started, and the server send “abortd” to stop the communicator. When I open the Manager to start communicator maunally, the commmunicator can start success.
So I don’t know the reason of this, it only appeared on Windows, and never appeard on Linux.2021-05-23 22:56:59 <WIN-CAC7VEJ6UUO><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2021-05-23 22:57:00 <WIN-CAC7VEJ6UUO><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2021-05-23 22:57:00 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2021-05-23 22:58:13 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Receiving commands aborted
2021-05-23 22:58:13 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Stop communication lines
2021-05-23 22:58:24 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Disconnect from SCADA-Server
2021-05-23 22:58:24 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> ScadaCommService is stopped
2021-05-23 22:59:32 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> ScadaCommService 5.2.1.2 is started
2021-05-23 22:59:32 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Load device library: KpModbus.dll
2021-05-23 22:59:33 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Load device library: KpDLT64507.dll
2021-05-23 22:59:33 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Load device library: KpDLT64597.dll
2021-05-23 22:59:35 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Load device library: KpIEC104.dll
2021-05-23 22:59:35 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Load device library: KpOpcUa.dll
2021-05-23 22:59:35 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2021-05-23 22:59:37 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Start communication lines
2021-05-23 22:59:37 <WIN-CAC7VEJ6UUO><SYSTEM><ACT> Start receiving commandsMay 24, 2021 at 11:20 am #8992
MikhailModeratorCould you check if Communicator already started successfully before you upload the project?
If Communicator is not fully started when you upload again, there may be an issue, because it should be fully started before stop.
May be starting takes a long time. if so, you should analyze the cause.
Try starting and stopping Communicator manually and watch how it behaves.May 25, 2021 at 11:58 pm #8999xdwokcn
ParticipantCould you check if Communicator already started successfully before you upload the project?
Yes,the Communicator has already started before my uploading. but it has been work well for serveal days.
Starting communicator usually cost 10~20 seconds.
May 26, 2021 at 6:40 am #9000May 26, 2021 at 2:10 pm #9001
MikhailModeratorCan you reproduce this issue using the built in drivers, like Modbus Driver?
May 27, 2021 at 7:54 am #9002xdwokcn
Participant@xdwokcn Do you happen to have a record of archived data in your drivers?
No,it only contains currenty data in drivers
May 27, 2021 at 7:57 am #9003xdwokcn
ParticipantCan you reproduce this issue using the built in drivers, like Modbus Driver?
Nearly 90% of devices are using Modbus Driver,and another is OPC UA.
May 27, 2021 at 1:08 pm #9004
MikhailModeratorNearly 90% of devices are using Modbus Driver,and another is OPC UA.
Good.
You provided the Communicator log. What is in the Server log at the same moment when a problem occurs? -
