ChartPro export data in hourly
Forum Home › Forums › Understanding the Software › ChartPro export data in hourly
  • #9067
    kcks66
    Hi Mikhail,
    I created an Hourly Real input channel to record consumption every hourly.
    https://ibb.co/qytM4vv
    However, ChartPro exported data in every minute. Pls advice for how should I configure to make ChartPro export data in every hour only?
    https://ibb.co/3cr6CjG
    Currently the export excel data has the same value for every hour.
    #9068
    ChartPro takes data from the minute slice and is not yet able to show the chart and export it in hourly format
    #9069
    Use the Elastic Report Plugin it can be set to the hourly version. But of course I would like to have such an opportunity in ChartPro
    #9073
    Fully agree with @manjey73
    #9075
    kcks66
    Hi Mikhail,
    Noted for the CharPro current design format.
    However, is there possibility to configure something like the Minute Data Report to become another option like Hour Data Report?
    https://ibb.co/y5L4fd0
    So I can add any desired channel and From-To date to export data every hourly?
    #9078
    This is planned for the future.
    #9081
    kcks66
    Hi Mikhail,
    That’s great. Looking forward to have this functionality.
    By the way, how to configure to have data in every hour?
    https://ibb.co/GTc0xYx
    #9082
    kcks66
    Hi Mikhail,
    I tried to play around with the Elastic Sample Report, is it at the TimeTime section type?
    <Section>
    <SectionOptions>
    <ID>Section1</ID>
    <SectionType>TimeTime</SectionType>
    <Subheading>Main Usage</Subheading>
    <SubheadingVisible>true</SubheadingVisible>
    <SkipFirstHour>false</SkipFirstHour>
    </SectionOptions>
    <Table>
    <DataItem cnlNum=”101″ calcType=”Val” calcTotal=”true” calcAvg=”true” calcMin=”true” calcMax=”true” colStyle=”col-xs” />
    </Table>
    </Section>
    #9088
    SheetOptions specifies the input parameters for the report. To setup report view, you should configure the report sections. For further questions about Elastic Report, please start a new appropriate topic.
