Forum Home › Forums › Runtime Bugs › Administrator Channel pane on LInux
- This topic has 6 replies, 3 voices, and was last updated 5 years, 1 month ago by
June 29, 2021 at 5:35 am #9164
zzz
Participant– Channel Input/Output right pane, grid view show value instead of caption for dropdown lists. e.g.
Objectcolumn show object ID instead of object name, and all other colunm with dropdown lists show value id instead of their text caption.– Editing value in sorted column, will trigger Administrator crash.
Some other area,
– Can’t stably scroll log to buttom in communicator, always automatically refresh to show first few lines. (and freqeuntly in very show time, thus bearly usable.)Runtime info:
Mono JIT compiler version 6.12.0.122 (tarball Mon Feb 22 17:42:49 UTC 2021)-
This topic was modified 5 years, 2 months ago by
zzz. Reason: mono, administrator, lin
June 29, 2021 at 7:36 am #9169
manjey73ParticipantThis is disabled in Mono because it does not work correctly. Therefore, there are ids of other tables instead of a list. We hope that in the next version, if you abandon Mono, everything will be fine.
June 29, 2021 at 12:30 pm #9179
MikhailModeratorUsing Administrator on Linux is deprecated and should be avoided. Microsoft killed this path.
June 30, 2021 at 4:56 am #9187zzz
ParticipantCould you explain what you mean by abandoning Mono ?
Do you mean abandon .NET for Administrator, or are there are other alternative for Mono on Linux?June 30, 2021 at 2:11 pm #9189
MikhailModeratorCurrently Rapid SCADA uses Mono on Linux.
Mono is OK for everything that related to logic processing and web application.
But Mono GIU apps, like Administrator, work bad on Linux.In the next version Rapid SCADA 6 we will use .NET5 instead of Mono Framework, both on Windows and Linux. Administrator on Linux will not work. You should edit projects on Windows workstation and upload them to Linux server.
If we find a sponsor, we can develop Web Administrator for any platform.
July 1, 2021 at 2:38 am #9195zzz
ParticipantOK, got it. So that is .net core which I alomost lost track of.
Does V6 and V5 server communication API has a lot of major change ?
July 1, 2021 at 10:43 am #9199
MikhailModeratorThe primary ideas are kept the same. API changed.
