Rapid scada on beaglebine black
Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Rapid scada on beaglebine black
  • #8986
    nex
    Hi
    Can I install rapid scada on beaglebone? Can I use the onboard I/O
    Thanks a lot
    Nex
    #8987
    What is Angstrom Linux based on?
    I very much doubt that it is possible to install Mono on this OS
    Debian for BeagleBoard
    If you install Debian, it is possible to start the system. At the expense of using GPIO, you need to look at what is implemented, if there is a libwiringPi assembly, then it is also possible
    • This reply was modified 5 years, 6 months ago by manjey73.
    #8991
    nex
    Ok , Thanks a lot
    #8993
    But to work with GPIO, you will most likely have to write a driver specifically for this PC.
