Viewing 15 posts - 1,456 through 1,470 (of 6,239 total)
  • in reply to: New release Rapid SCADA 6.1.x #13455
    Rapid SCADA 6.1.4 has been released:
    – Added the Code column in the Channels table. It can be used for integration with external software.
    – OPC Classic driver supports sync mode for OPC DA.
    – Other fixes and improvements.
    in reply to: Chart Pro Data Timestamp Metadata #13454
    It’s weird.
    Anyway, today we published PlgChartPro 6.0.2.1. Please use the latest version.
    in reply to: can’t convert opc da with 5 layers to opc ua #13453
    I met this bug earlier with old OPC DA servers. I think, it is related with OPC client libraries, and we have nothing to fix in the driver. You can add OPC tags manually in the device configuration XML file.
    in reply to: Api connection #13436
    Note: you have to change ScadaWebConfig.xml, set AllowAuthApi to true.
    in reply to: Api connection #13435
    Connection is OK, but login failed. So check the log files ScadaWeb.log and ScadaServer.log
    in reply to: Chart Pro Data Timestamp Metadata #13434
    Please download and install Chart Pro again. We’ve fixed this small bug without changing the version number.
    Note: chart legend can be moved to the right if needed.
    in reply to: rapidscada v6.1 opcDA SourceCode (DrvOpcClassic.Logic) #13428
    OPC Classic Driver source code
    This code is not on GitHub, because it refers the proprietary OPC dlls.
    • This reply was modified 3 months ago by Mikhail.
    in reply to: Api connection #13423
    Check TCP port that is used by the web application.
    in reply to: Multiple Levels of View Folders #13422
    1. Create similar file structure under the Views node.
    2. Specify views in the Views table.
    in reply to: Elastic Report #13421
    Is there a way to make it into minute?
    This is possible in version 6.
    in reply to: Events and Ack #13416
    Interesting idea. I suggest to try creating a module for the Server app, because it’s more flexible than formulas.
    in reply to: Don’t display some events #13415
    Instead of that formula, use Cnl; 15 which fits for channel of the Input/output type.
    in reply to: Dashboard Plugin #13414
    Please check this link for more info.
    in reply to: HeideSQL Access to Default PostgreSQL Archive Database #13413
    Check the tools such as DatViewer-v6 and TrendTableViewer-v6 that allow to view *.dat files. Tools for editing have not been developed yet. Use ScadaTestClient-v6 to update data in archives.
    I hope that the DAT viewers will be updated to editors later.
    in reply to: HeideSQL Access to Default PostgreSQL Archive Database #13412
    *.dat format is not proprietary, it’s documented and can be used by anyone for free.
    I suppose, you can use HeideSQL or DBeaver to connect to PostgreSQL. However, there is a default tool, named pgAdmin. Username, password and port are specified during PostgreSQL installation.
