In Grafana settings, enable open in frames. By default it is disabled.
MikhailModeratorCould you make a screenshot of your CSV for demo mode?
MikhailModeratorJust copy the project folder. I recommend to use GitHub for storing your projects.
MikhailModeratorWhat do you get in ScadaWeb.log?
July 4, 2024 at 12:45 pm in reply to: Elastic report different default DateTime format for Excel #14884
SCADA\Config\ScadaInstanceConfig.xml
Another issue is not related to Elastic Report. Find a corresponding topic.Like in the “Minute Data Report”. Is this also feasible, or do I have to create a separate report for each group of values?
It’s supported in v6.
July 3, 2024 at 10:58 am in reply to: Elastic report different default DateTime format for Excel #14871
It may depend on Rapid SCADA culture that is set in the Administrator application.
MikhailModeratorIf you use default Rapid SCADA archives, copy the archive data files for backup.
MikhailModeratorAnd about demo mode ? What’s the trick to make the driver read data ?
It is useful to simulate a device with your data.
MikhailModeratorWhat do you mean by cleaning a server?
MikhailModeratorSpecify the report type
@ElasticRepas shown in the manual.In version 5, use only English characters in file path.
MikhailModeratorI am still ending up with the same bad gateway error.
What is in the nginx configuration related to Rapid SCADA?
Does http://localhost:10008 work?I’m concerned that the third link talks about “server blocks” which I felt like mostly didn’t apply to my install.
Before fix the bad gateway issue, I suggest to use the nginx configuration from the Rapid SCADA installation package.
MikhailModeratorThank you for providing a solution.
New line is required. Also you can delete the existing file and create a new one. It should work.Is it possible to get rid of this mathcing time constraint ?
This is possible to make a time difference as a parameter. I’ve made a note in the back log. If you need it in time, we can do that on paid basis.
In the module settings, the device 47 is specified. While in the Communicator you use the device 50. Probably, they must match. -
