Viewing 15 posts - 751 through 765 (of 6,219 total)
  • in reply to: Utility Pack 6.0 Instructions #15466
    Open the Archives table of your project. Please check if there is an archive with bit 11 in the table?
    in reply to: Compare values and send modbus value #15464
    Send screenshots of the settings if you need more details.
    in reply to: Compare values and send modbus value #15462
    You need to create a new channel of the Calculated type with a formula
    Val(101) > Val(102) ? 1 : 0
    Then use the number of the new channel in the module in the trigger. To use the channel value in a command, you need to set output formula of the channels that are used for sending commands: Val(101) / 8
    • This reply was modified 1 year, 6 months ago by Mikhail.
    in reply to: OPC DA no values received #15461
    in reply to: Rapid scada data streaming API #15451
    will I be able to publish scada data to a standalone mqtt broker, so that other application can subscribe it to get the data ?
    can you mention the steps to enable and communicate Mqtt Publisher
    Yes, you can. To get more info about configuring that driver, please create a new topic related to MQTT Publisher.
    in reply to: Error at Exporting Data Manually with ModDBExport #15450
    It’s possible to send a command via the Administrator app, but I can’t find information about the required command format, because that version of the driver is too old and outdated.
    is it possible for me to use a cloud server instead?
    Rapid SCADA works well on a cloud server.
    Note. Recently Rapid 5 was removed from the download page. Use the 6th version which is more secure.
    in reply to: I have issue about database import (MYSQL) #15449
    To display strings in the web app, set channel data type to Unicode string.
    in reply to: I have issue about database import (MYSQL) #15448
    The driver works with numbers and 4-character strings. Long strings currently not supported by the driver.
    in reply to: OPC DA no values received #15446
    Thank you for the info.
    In addition, try changing the service user as shown here (ScadaComm6 service). There is a chance to run Communicator as a service.
    in reply to: OPC DA no values received #15436
    OPC DA (Classic) may be unpredictable. It’s a bad technology. You should use OPC UA instead.
    The checkbox is in the screenshot https://ibb.co/wzjYYrN
    in reply to: Error at Exporting Data Manually with ModDBExport #15435
    The proper way is upgrading Rapid SCADA to the version 6 and after that solve export questions.
    in reply to: Error at Exporting Data Manually with ModDBExport #15434
    Command type of the output channel should be binary.
    in reply to: Error at Exporting Data Manually with ModDBExport #15433
    In the screenshots, the number of the output channel is 201 while in the configuration form 631 is specified, which is wrong. It should be 201.
    in reply to: Extension DLL Constraints #15432
    Name Constraints
    Class names and namespaces are important. Locations of the classes’ files are about code style.
    in reply to: Extension DLL Constraints #15430
    Module Placement: \ScadaWeb\wwwroot\plugins
    Plugins include DLL which is located in \ScadaWeb\ and static files in \ScadaWeb\wwwroot\plugins
