May be some other application affected network communications. Windows update also may be the cause.
I would prefer Linux for server software that needs to run 24/7.
MikhailModeratorYou don’t need to add commands in the device properties. You can just write data to elements of subscriptions.
In the Administrator app, right-click the device, choose Send command. Type the tag code as a command code and send. Does it work? If not, check a communication line log.
MikhailModeratorLink in the store is https://rapidscada.net/store/Module/en/KpDbImportPlus
MikhailModeratorDear Bryan,
Please copy in this topic a part of a communication line log that contains error details.
November 22, 2024 at 11:08 am in reply to: Sending custom data from SCADA Admin app to Server #15641
If a path should be entered in the Administrator application, it can be done via module user interface. Like Auto Control Module does, for example. Module configuration is stored in an XML file as a part of the project.
I suppose, the plugin will generate the computer code when you upload the project, containing a scheme (mimic diagram) containing that components. And activate the plugin, of course.
I have my ‘own’ project, so not hello world from the installation process. Does this mean that the files have to be copied to a different location?
ChartPro*.xml files should be copied in your project folder (where you saved it) as shown in the above post.
This reply was modified 1 year, 4 months ago by
Copy PlgMap.xml from the distributive package to your project. Then upload the project again.
Thank you for the update.
MikhailModeratorFormulas of the calculated channels are called many times a second.
Formulas of the input channels are called when data comes from Communicator. By default, Communicator sends all device data every minute. May be this is the cause.For what channel number do you use the function Timer48hactief?
MikhailModeratorHow to connect a device that only supports DNP3?
Could a Modbus-DNP3 gateway be an option? What else is there?Hello,
Use a 3rd party OPC server or a hardware gateway.
Try, for example:
/View/1
or
~/View/1where 1 is a view ID.
