Viewing 15 posts - 571 through 585 (of 6,219 total)
  • in reply to: I would like to inquire about the visible/invisible function. #16120
    Connecting cameras also discussed here.
    in reply to: I would like to inquire about the visible/invisible function. #16119
    1. If you are asking about schemes, we plan to implement that feature in the future.
    2. To display a video stream you need to convert it to a web format. See this example.
    in reply to: Using AD for login #16112
    Have you created a PostgreSQL database and specified it in ScadaInstanceConfig.xml?
    in reply to: Using AD for login #16109
    Download is not needed in 99% of cases.
    When you upload a project, it is saved. You can also save the project by the Save button.
    If you gen an error, check the error details in the log files.
    in reply to: Change output state by formula #16108
    I thought all configurations should be done for channel which is referred in formula but configuration should be done on channel which execute formula, I’m right?
    Both is possible. A channel should not call SetVal for itself. When you need to change a channel itself, return a new value from the formula.
    in reply to: Using AD for login #16104
    1. In the Server – Modules page, activate the ModActiveDirectory module.
    2. Configure the module properties.
    LdapTest utility may help to find proper parameters.
    in reply to: How to use the chart #16103
    How to use the chart in the Extra Scheme Components Plugin,
    Specify the component properties to display a chart on a scheme.
    and how to change the default range of the scale from 0 to 100 to another range?
    Scale can be changed only manually by a user.
    in reply to: Change output state by formula #16099
    Val(52) is a wrong formula because it refers the channel itself.
    in reply to: Change output state by formula #16098
    V0.2 is the tag code of the channel. When a user sends a command to this channel 52, the command value should be transferred to Communicator. You can see it in ScadaComm.log.
    in reply to: OPCUA DA Gateway #16094
    Cool!
    in reply to: Farm Management Module #16093
    in reply to: OPCUA DA Gateway #16091
    May be you should convert the data tag to a number and store it in a separate channel.
    in reply to: IP address And System Time #16090
    how do I configure Linux to be static ip addresses?
    Probably, this question is not related to Rapid SCADA configuring.
    in reply to: IP address And System Time #16089
    how to display the IP address of each network port of the device in the rapidScada View?
    Put a static text label on a scheme, for example. You cannot access device properties from a view.
    How can I write the time data to the Linux system in View and set the time?
    Create a channel of the calculate type. Use Now() as an input formula of the channel. Choose proper channel format.
    in reply to: How do I send setup data to Modbus device #16087
    Commands cannot be sent by a script. Commands can be sent by a module.
