Viewing 15 posts - 4,741 through 4,755 (of 6,219 total)
  • in reply to: how to send a modbus value #3760
    does rapid scada have a text box where i can set a value and then send it to the Modbus Device
    Yes. You need:
    1. Create an output channel.
    2. Specify this channel in a scheme or a table view.
    3. Configure a command in your Modbus template.
    Also read this article.
    In case of follow up questions, ask here.
    in reply to: inject a gauges or chart to the view #3759
    Probably, you should create a plugin that provide a gauge as a control to insert into a scheme. The example is PlgSchBasicComp
    Could you translate the error message?
    I suppose, the log says that we can’t connect to a device. Is it possible that the device doesn’t support several connections in parallel? Are you sure that the port 530 is correct? Usually 502 is used.
    For testing, you can try Hercules utility to connect. What is the result of this test?
    The forum does not allow to upload images, just links to them.
    in reply to: Driver gallery #3751
    I’ll push some drivers in the future.
    Would be great.
    This list integrated in each Webstation app is prototype of a gallery. When there are more modules, we can create filters and other features. May be add such web page on our website.
    in reply to: Roadmap #3749
    in reply to: Driver gallery #3748
    I was thinking about it too.
    What do you mean talking about a gallery?
    I just created scada-community repository. I hope, it will be used for the purpose you talk about.
    “scada” repository is for core applications and modules.
    in reply to: Nuget package reference #3747
    Probably it’s better. Maybe this will be changed in the future to nuget.
    in reply to: Using the new basic scheme components #3744
    Thank you too. You helped to find and fix the bug!
    in reply to: New Agent Application #3742
    You should allow incoming connections for the TCP port 10002 in the settings of Windows firewall to enable access to Agent.
    in reply to: PID Control #3741
    The existing Link component allows to redirect to another scheme where you can put needed components. It is planned to add a popup dialogs feature for links in this year.
    in reply to: Using the new basic scheme components #3740
    You can do a trick:
    1. Create a folder C:\SCADA\ScadaWeb\plugins\SchBasicComp\lang\
    2. Copy the PlgSchBasicComp.en-GB.xml into this folder.
    The fix of this bug will be included in the next version of Rapid SCADA.
    in reply to: Using the new basic scheme components #3738
    The web app must be in C:\SCADA\ScadaWeb because of this bug. Is it?
    in reply to: New Agent Application #3735
    Control RAM on Linux. Agent uses WCF technology that has a memory leak bug on Mono .NET Framework.
    in reply to: Using the new basic scheme components #3731
    I suppose, the cause is your localization. I reproduced the bug. What culture did you set for Rapid SCADA?
    in reply to: Using the new basic scheme components #3730
    Also try unblocking the DLLs in C:\SCADA\ScadaWeb\bin
    See this.
